Question about Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2630SH circ. fan makes noise. How can I change its defrost timer.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
You will need to replace the defrost thermostat in the freezer section. Here is the part to order.
Posted on Dec 03, 2012
  • Buqraat Dec 03, 2012
    Thanks for the reply. One more question...where is the thermostate located? Thanks
  • Richard Roth
    Richard Roth Dec 03, 2012
    It sits on top of the coils in the freezer. If you remove the back panel in the freezer you will see it.
3 Suggested Answers
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
  • 884 Answers
SOURCE: What's your problem?rs2630sh samsung fridge center hot
Do you mean the divider? It's hot to stop the door freezing to it. Nothing to worry about!
Posted on May 18, 2012
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fridge freezer making a loud buzzing noise
My Samsung refrigerator (rf263aebp) was making an awful buzzing noise in the rear after only 1 year. I solved the problem by loosening the rear panel that covers the fan. Apparently, it was too tight and was rubbing on something (the fan?) and causing the noise.
May 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
The right side of the fridge is not cooling well. the freezer is fine, but it also making a strange noise
Hi and welcome to FixYa, I am Kelly.
That strange noise your hearing is probably the fan blades of the evaporator fan striking ice build up on the evaportor coils. This symptom is typical of and automadefrosting problem.... or someone left the freezer door open for a very long period.
You can try doing a manual defrost by unplugging the unit and place a fan blowing into the freezer compartment / compartment making noise for about 2 hours. (makes a water mess) After 2 hours tend to the water mess and restart the unit. Most likely the noise you heard will be gone... for a few days. If you have an automatic defrost problem the noise will return in about 72 hours as the ice build up gets larger on the evaporator coils.
Depending on date of manufacture this unit can have either a manual defrost timer or an adaptive defrost control board that controls the automatic defrost. .
Thanks for choosing FixYa,
Kelly
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge freezes up
clean condenser coil, check fan is running inside freezer, replace defrost timer.
Sep 08, 2009 | Samsung RS2630SH Side by Side Refrigerator
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
