Question about ViewSonic N3735W 37 in. LCD TV
Screen resolution - Viewsonic N3735w
I have connected my pc with my Viewsonic TV N3735w and using my TV as monitor. I have also installed the driver for N3735w. My system shows two screen resolutions:
(a) 1024 X 768
(b) 800 X 600
800 X 600 comes too big and
1024 X 768 stretches every thing horizontally and vertically out of screen and I am not able to see everything.
Any suggestions / tips?
Thanks in advacnce.
  • Jaspreet Makkar Jan 11, 2009
    I resoloved the issue.
    I used "Auto Set Resolution" settings in my TV and everything worked great.
    Just wanted to share this just in case someone else faces the same probem.
    Thanks!
    President:
  • 2,692 Answers
Buy a monitor that wil accept your video card size  resolutions?
Posted on Jan 11, 2009
Where can I find the right driver to install a Viewsonic VE710b Flat Panel Monitor? I am running Windows 7, 64-bit **This connects to my VGA port, I already have 36" Samsung conntected via HDMI, and
Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Oct 10, 2014 | ViewSonic Computers & Internet
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
How to change T.V settings so that lap top computer can be seen
Are you using the VGA port or one of the HDMI ports? Are you using an HDMI to DVI cable? (then check if you have Single-link or Dual-link DVI; the cables are not interchangeable when you create the adapter in the cable.) Make sure the TV is on (and pointing to the desired input although it will possibly go into a power-savings mode) before turning on the laptop.
It is more likely to be an issue on the computer side. Make sure your BIOS and device manager have the video port turned on. (Many will disable the device for power-savings.) You may need to reboot after seeing a message about the drivers being loaded when the computer sees the laptop. Once the port is active, Win7 and Vista let you change the video output if you click on the Desktop (anywhere without an icon or program window) and choose Screen Resolution. Then look for a line about multiple monitors and choose how you want the monitors to display.
If you need a driver try:
http://www.viewsonic.com/products/lcd-tvs/n3735w.htm#tabbox_downloads
(click on More drivers if you have a 64-bit OS)
I hope this helps.
Apr 20, 2010 | ViewSonic N3735W 37 in. LCD TV
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
My viewsonic monitor VA1703wb image doesn't fill the screen
There are a couple of reasons for this problem.
1. The screen resolution was set too low. Try 1024 X 768 or higher.
2. If you cannot change the screen resolution then the video driver was not installed or the wrong video driver was installed.
Dec 04, 2009 | ViewSonic VA1703wb Monitor
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
ViewSonic N3735W 37 in. LCD TV Logo
176 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
