Question about Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft.
WIRING PROBLEM OF FREEZER MODEL FS-2D-57
We have the problem of timer switch,defrosting thermal and wiring system of this model of freezer, please could you send to about wiring diagram?
  • 72 Answers
Having wiring problem freezer works but fans dont come on aod defrost timer dont kick in need a wiring diagram the serial number is . 88202021 and model number is . gf2ssd for a nor lake reach in...
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Oct 10, 2010 | Nor-Lake Freezers
Side by side freezer frost in the back and food thawed out....the freezer is a 9 and fridge 5...What should i do? it is a couple of years old...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jun 13, 2010 | Freezers
Freezer in side by side isn't freezing, but the other part is OK. What to do?
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 04, 2009 | Freezers
Foster freezer keeps going into alarm: (code:DEF).
Check to see if the defrost system is working.
Sep 24, 2009 | Freezers
Sides of freezer are hotter than normal. no air sound when closing door,is this a defroster problem?
First check the condenser fan underneath near the compressor. It should run when the compressor runs.
Sep 24, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Defrost cycle on my elecrtolux ER 7926/1 B fridge freezer seem to be to long and temperature in the freezer drops down to 0 C every defrost cycle, does enyone have a wiring diagram for this model please
No i dont but i could suggest you check the heating element and the clixon that connects to the evaporator. If the heater does not function, it takes a much longer time than usual to switch the freezer on.
Sep 21, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
My upright freezer won't self defrost. Frost builds up right awa
Sep 19, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezer is on and just stopped working
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
DOES NOT MAKE ICE
Aug 13, 2009 | Freezers
Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft. Logo
209 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
Steve Allison
Steve Allison
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
