Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
My Talea Ring Plus was showing this error message even though bin was full of coffee and grinder working.
Error message was "fill container with coffee".
4 Suggested Answers
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
  • 20 Answers
SOURCE: Saeco Talea Ring Plus
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
  • 5370 Answers
SOURCE: We have a Saeco Talea Ring which is now about 3
Clean the coffee filling container and insert bit fine grinned coffee beans directly then see.This problem is faced by many other saeco coffee machine users .Try this.Grind the coffee beans separately in a mixer, grind it very fine.Then insert/ fill the coffee fill container with fine grinned coffee bean powder.Then see, if you get same error.If you still get error then the coffee machine needs servicing, the coffee is not entering the machine.Its getting clogged in the drawer.But if it works with coffee grinned separately then its grinder problem, its not grinding the coffee fine.------ This will help you to confirm the problem.Is it grinder problem or the machine needs servicing.- Thanks.Helpmech.
Posted on Jun 28, 2011
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Nov 11, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
