My kenmore washing machine make a loud thumping sound,model number 41744042400 just replaced shook absorbers and still thumping. think i have to take the drum appart?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Are the springs intact that hold the drum also?
Posted on Dec 03, 2012
  • 3 more comments
  • jason Dec 03, 2012
    yes, sounds like the noise is coming from inside the drum. it just in 1 spot that it kinda clanks. is there somthing between the stainless drum and the drum housing that could make this happen?
  • Richard Roth
    Richard Roth Dec 03, 2012
    The paddles inside the drum snap in on some of those models. See if one is loose and post back to me.
    is that inside the stainless?
    cause ther is a dryer on top that dont really want to take off if i dont have to0
  • Richard Roth
    NO, you can check it from inside. This model may not have the snap in paddles.
the dr
  • 447 Answers
SOURCE: Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Posted on Oct 03, 2007
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
  • 156 Answers
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
SOURCE: Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Posted on Mar 07, 2008
SOURCE: Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Posted on Aug 23, 2008
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
The washer is a Kenmore, front load style, from 2003.I would like to know if I really need to replace my washer, or a repair is feasible at all.
Have a service engineer to come and have a look and assess the extent of the problem, depending on the issue he will be in a position to tell you.
After that it depends on how old it is etc...
Aug 10, 2015 | Washing Machines
My Kenmore 3.6 cu. ft. High-Efficiency Top-Load Washer is making a very loud thumping noice what can it be and how can i fix it
The flexible joint under the tub needs to be replaced. This will require disassembly of the cabinet to access the joint
Jan 17, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model - 41744042400, will not cycle through. It stays on the same setting the whole time. Whats the problem and how do I fix it?
Possible fault with the main program controller unit, needs a replacement if the wiring and the controller panel is seen to be in order.
Oct 09, 2012 | Kenmore Washing Machines
The tub makes loud thumping noises and seems to drop several times during a wash with very loud thumps and moves the machine.
The shaft that holds the drum sounds like its shifted or gotten bent (sometimes due to moving home, or overloading the machine)
One way to fix this is to open the unit and try to bend the shaft back to an equal kilter, but bending it back won't fix the problem forever, as the metal will now be weakened an d washing machines have fantastic G-force when spinning so weak metal won't keep forever,
but if you have your model number you can always get a replacement shaft and fit it yourself so its like new.
Hope this helps you.
Jan 01, 2010 | Washing Machines
Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Jul 06, 2009 | Washing Machines
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Oct 02, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
