Question about Hilti Te 706 120 Volt Breaker
I have an old hilti breaker bought on ebay, i must add i know nothing about these power tools but this came with the needle attachment in it i have sds chisels and wanted to break down a chimney ****** at home there are no other attachments ie sds chuck and i can't see any way of detaching the needles Any help as at the moment all i have managed to achieve is a chisel bit jammed between the needles and it does not hammer at all just a low vibration what do i do to make it work please?
rowdy45176
  • 2176 Answers
SOURCE: I am the owner of a TE 905 Hilti Jackhammer,
If you havent found them yet call 1-800-879-8000 and they will be more than willing to help you.
Posted on Jul 16, 2009
  • 2976 Answers
SOURCE: How do you change out the chisel on the Hilti TE
Pull back on the chuck head and turn it. The Chisle should fall out.
Posted on Oct 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: Hilti te5 problems
go to Hilti.com and you can download a breakdown for this tool. Let me know if you need more help with the repair.
Posted on Mar 12, 2010
  • 8404 Answers
SOURCE: how do you remove the bit from the chuck of a TE
Slide the collar on the chuck to the rear (toward the handle)
Posted on Nov 22, 2010
SOURCE: my hilti te-75 drills but is not hammering
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Posted on Feb 07, 2011
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
How much oil put in hilti t15
Thats the most delicate question on fixya
45ml or 50ml hd20 or an other cheaper sae20-20 can also be used and also bought by Hilti
Be aware of all the secrets of the tight-toleranced parts and bearings by this brand . in case you will service this by yourself because its not comparable with other brands by using a consumables kit. because only change a few parts will not made a succesfully repair because of marketing technical developments because everything works very close accuratelly together by brand Hilti. the impact bold you will see perhaps optional see nothing but measure it on the seal can make a decision for the whole machine.
Hilti and Duss are both one of the best tools but have a complete service nessecary if there are the working hours on it.
HILTI TE15 Service Manual free download schematics eeprom repair info for...
Jan 27, 2016 | Hilti Drills
Bought hilti te 76 atc combi hammer breaker from ebay,it came friday and ive tryed to use but it wont except my sds max bits,seems like it carnt get past the two balls insde the shaft of thr chuck ,thanks
try turning the bit by hand a little while just pushing the bit in. On those you don't use the collar to install. You also might want to try and putting a SMALL amount of grease on the shank and retrying. Let me know if you still need help
May 15, 2011 | Drills
Hilti TE 505 does not drill
The Te505 is a breaker only. So it will not drill. Any Hilti tool that starts with TE and is followed by three digits is a breaker only.
Sep 22, 2010 | Hilti Drills
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Looking for a supplier of the speed control part
The best bet is to go on to ebay and buy a used one or onto craigs list. Unfortunately when these tools get a few years old, for Sears [craftsman] for example it is 10 years. Joe
Mar 17, 2010 | Drills
Hilti te5 problems
Mar 12, 2010 | Hilti Drills
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Hilti Te 706 120 Volt Breaker Logo
1,264 people viewed this question
Top Hilti Hammering Experts
Todd Arndt
Todd Arndt
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hilti Hammering Expert? Answer questions, earn points and help others
