Question about Frigidaire GLTF2940ES Front Load Washer
The washer does not spin, what could be the problem?
The washer works except for the spin cycle. While in the spin cycle the machine just hums.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Replace the door lock assembly. Here is the part to order.
Here is a video to show you how to replace the lock.
Posted on Dec 03, 2012
Krazytech
  • 725 Answers
SOURCE: 14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Posted on Aug 13, 2008
SOURCE: Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Posted on Jun 06, 2007
ngfam1
  • 639 Answers
SOURCE: Issue with switching to rinse cycle automatically.
Dear G.Arnold,
ngfam at you service
If you are under warranty it's FREE
Sounds like you need service! no cost to you!!!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
IFIXALL
  • 868 Answers
SOURCE: washer wont wash- nothing...
Remove the back panel if it has one and look for belt that is off.Before you put it back on check the pulley for any looseness.It should be tightened if you need to.I'll assist you further if you need my help. Please Rate this !!!
Posted on Sep 09, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
Washer fills with water but will not continue with the wash cycle. There is power to the machine because I can her an electrical humming when I try to start the cycle.
If the water in the machine empties when you move the selector to spin but does not spin, you may have a machine that uses a coupler to connect the motor to the transmission (many Kenmore models and others). When the coupler fails, and they do, then everything will work except for the agitator. If this is the case, you can see it if you flip the unit over and look.
Jan 07, 2010 | Kenmore Washing Machines
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Kenmore series 70 washer
Have you checked to make sure that the motor is turning?
Feb 08, 2009 | Kenmore 22422 Top Load Washer
Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
Jan 04, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
