I can't access closed caption
The menu won't let me go to closed captions
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
What is connected to the set for signal---a cable or sat box or what?
Posted on Dec 03, 2012
circuitcity
  • 137 Answers
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Posted on Dec 09, 2007
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
Agent Jason
  • 78 Answers
SOURCE: close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 16, 2008
  • 418 Answers
SOURCE: Can not get Close Caption to dispaly>
CC in the TV will only work while watching the TV's antenna or cable inputs; not the video inputs.
Posted on May 09, 2010
alexander404
  • 276 Answers
SOURCE: My Vizio VA19L 19'' LCD Television's closed
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Posted on Mar 05, 2011
CLosed Captions won't go off. Setting says they are off.
Go back and just "look" to see if the captions are still turned off.
if it is still on CC1 or CC2, the captions are still on.
If they are, you must turn captions off and then follow on screen prompts to make sure they are indeed off.
(Did someone turn on the captions on your cable box or other receiver?)
(If they did, this may be the reason that you can/t turn them off on the TV !)
Apr 02, 2013 | Televison & Video
CLOSE CAPTIONING WON'T TURN OFF
Go back into the menu of the TV and go through the choices. One of them is to turn on/off closed captions!
Jan 02, 2013 | RCA Televison & Video
Closed Caption
try to go to menu and find the CC close caption option there..
Aug 25, 2012 | Sanyo DP26640 LCD TV
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Logos on the bottom of the screen won't disappear
that logo is CC close caption..to remove it go to the menu and find close caption option then select off then press enter..
Jan 02, 2012 | Samsung LN32A330 32 in. LCD TV
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
