Question about Samsung Dryers
Not heating model dv419ew
    Top Expert:
  • Samsung Master
  • 9,472 Answers
Check all the thermostats for continuity.
Posted on Dec 03, 2012
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
No heat in my dryer
Try Google---the model number with replace heating element, etc as there are many good videos for this on You Tube. It will vary from model to model.
Dec 22, 2012 | Dryers
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
How can i use my carrier AC model GenX2 as heater in this cold conditions
If your a/c is heat & cool model you can get heat. Otherwise cool only.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 05, 2011 | Carrier Heating & Cooling
My a/c will not heat up. I have a Samsung model: AW12ECB7
I think it's window 1 TR. Window a/c having heating element behind cooling coil. Please check your thermostat setting +5 degree from your room temp. and also model should be in heat mode. If still not heat works, check power to heating coil with volt meter. If not may be heating sensor problem. Replace it.
Dec 25, 2010 | Samsung Heating & Cooling
Window AC Model No. : LG LWA18G 2DF1AK42 IS THERE INBUILT HEATING FUNCTION? HOW TO USE?
Please try to understand with your model, the tonnage and also whether it's cool only or heat & cool. 12,000 (12)...........means 1 TR. with this help your a/c is 1.5 Tr and if it's heat and cool definately there wil be indication in the model cde it self. Ex.......A18TH DF..... like this. There will be H added in the model code itself. Yours is not heat mode. Is it helpful?
Dec 13, 2010 | Amana PTC094B35AM Air Conditioner
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
DuoTherm Model 59516.331 needs heat strip added
MODEL SERIES: 579XX, 590XX & 59516 (60XXXX, 61XXXX ON PAGE 2) ALL MODELS ARE PREWIRED WITH A POWER RECEPTACLE IN THE ELECTRIC BOX FOR EAS Y INSTALLATION
USE PN 3101121.030 HEAT STRIP,FOR NON-DUCTED MODELS
Dec 12, 2008 | Dometic Rooftop RV Air Conditioner
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
