Question about Dishwashers
Need specifications for hoover soft wave D7610 dishwasher
barkencoa
  • 3463 Answers
SOURCE: machine washes o.k. but does'nt spin
If you have not already done so, I suggest you remove the motor, and check the brushes for wear.
Please rate my solution.
Thanks.
Posted on Nov 08, 2009
barkencoa
  • 3463 Answers
SOURCE: my hoover soft wave wash and dryer spins normally
If you have not checked the filter, then you must do so, it is usually located at the bottom front left of washer.
If it has a screw in the handle, then undo the screw first, then unscrew anti-clockwise to remove and clean.
Thankyou.
Posted on Feb 02, 2010
Daniel S
  • 4323 Answers
SOURCE: my hoover soft wave maxi 1600 that stops on spin
Hi
Two things can cause this issue...first when the washer is unable to drain completely it won't spin, to solve this you can take off the bottom front panel and then clean the drain pump assembly. If the water is draining fine then the issue can be with the door lock assembly and should be replaced. If the door lock sends signal to the control that the door is not closed the washer won't spin. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 19, 2011
  • 6277 Answers
SOURCE: i just need to know
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 14, 2011
BADBOYJAY
  • 264 Answers
SOURCE: HOOVER SOFT WAVE MAXI 1400 KEEPS WASHING. HOW DO YOU STOP THIS? IS IT THE BELT?
no its not your belt it sounds like you programmer is on its way out but if i was you check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Posted on Nov 03, 2012
User manuals for: Hoover soft wave model number HSWD 126-80 and Servis washing machine Caress 1000A, model no: M3101A If someone could help that would be great :-)
Manual
John C.
Sep 22, 2011 | Washing Machines
Instructions for hoover dishwasher modelHD95M. Acquired above mentioned dishwasher but button uses have rubbed off.
Please check the link below and post your query to the contacts or call up for assistance:
www.hooverdishwasher.com
www.bestdishwashers.org/???hoover-dishwashers.html
Sep 29, 2010 | Hoover HD95M Free-standing Dishwasher
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
Aug 07, 2010 | Hoover AAA160 Front Load Washer
My hoover soft wave wash and dryer spins normally but will not drain. the hose is clear, also the waste pipe?
Thankyou.
Feb 02, 2010 | Washing Machines
Machine washes o.k. but does'nt spin dry (hoover soft wave auto - washer 1000 )
Thanks.
Oct 08, 2009 | Hoover AAA160 Front Load Washer
Need a new manual for hoover 6612 dishwasher please could you recommend where i find one
Hoover Support, Troubleshooting & Customer Service by FixYa Help with Hoover common problems, free Hoover manuals, user guides, reviews and tech ... Hoover Dishwashers. We found 499 products in Hoover. Air ...
Aug 18, 2009 | Hoover Dishwashers
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
