Question about Panasonic CQ-DPX33 CD Changer
WTF over? Can't insert a CD?
Not sure what the problem is. Is there a hard eject somewhere? how does it work? The eject button does nothing and for some reason it will not accept a CD. I checked the alignment of the removable face and looked for any obstructions. Can't seem to see anything inside the slot as it is covered adn I can't figure out how to bypass it. Just bought the vehicle that has this installed and miss my CDs. Thanks in advance for any help offered.
  • 1,056 Answers
See if there is any reset button which is usually located easily once the face is off. You need something with a small poited end. try not to use metallic object. If you have to make sure it goes in straght so as not to slip an ground something. Good luck this solve the problem sometimes.
Posted on Jun 28, 2009
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
Tip
CD Insert Without pushing a button!
This will not work with a Laptop drive unless it is the slot loading type.
We already have 'Eject' when we right click the CD/DVD drive from (My Computer), which ejects the drive tray. But to insert the tray inside,we have to manually push the insert button on CD/DVD drive.
Another way most PC owners insert that CD tray is by pushing the tray itself. I'm sure nobody mentioned this when you got that PC, but that push to insert feature (Also called the bump feed) is not really safe to use over time. If you happen to say, push too hard because you are in a hurry, the gear which pulls your CD tray in can skip a tooth, making that CD or DVD open and close all by itself, or even worse, making it stay locked tight forever.
Here is a trick that allows you to insert the drive tray without actually touching that button. Simply by putting the 'Insert' sub-context(as shown in above figure) menu on the CD/DVD drives Context menu. For this to happen, we need to use a dll file from our windowssystem32 folder.
First of all, download this file CDEject.zip and extract it. There will be two files CDeject.dll and CDeject.reg. Now follow the step by step procedures.
1. CDeject.dll -> copy this file to X:windowssystem32 folder (here X is your corresponding drive letter, usually it's drive C:)
2. CDeject.reg -> execute it. It shows a warning message, accept that and click OK.
Now try right clicking your CD or DVD drive and click eject, then right click again and choose insert.
Amazingly cool isn't it?
So far I haven't found a way to make the CD hop in the tray all by itself, but I am still hopeful.
And you thought you couldn't program!
Have fun with that!
Please Vote for this Tip if you found it helpful.
Bob S.
on Apr 02, 2010 | Computers & Internet
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
The CD rom tray will not open.
just watch carefully on cd drive front there is a tine hole somewhere below the door area . now u need a very thin rod or something to insert in to it. there is a button inside that hole so while pressing that button press the eject button. hopefully ur cd drive door will open
Apr 20, 2010 | IBM -3509707 External 4x CD-ROM Drive
I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Oct 27, 2009 | Alpine CDA-9883 CD Player
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Panasonic CQ-DPX33 CD Changer Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
