Question about Kenmore Elite 45986 Front Load Washer
What is LD means showing to my washer - Kenmore Elite 45986 Front Load Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Ld is for long drain error.
Check to be sure the filter is clear.
Posted on Dec 03, 2012
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: What does it mean when LD shows in the display on my washer?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
'Ld" sign is showing in
Hello.
What this code means indicate that the door of your washer is not well close .
L= LOCK
D=DOOR
So what you need to do to solve the problem is to open the door of the washer then close it properly.
Good luck.
Thanks for using fixya
Sep 06, 2011 | Washing Machines
Machine stops during cycle
"LD" stands for long drain meaning that the pump could be bad or that it just needs to be cleaned out.
Jul 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Message LD on washer
L D code meanning long drain. lint causing the problem . and restricting the pump inlet .. remove pump and clean out .. ****
Dec 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 03, 2009 | Kenmore Elite 20972
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
