Question about Compaq FP 7020 17" Flat Panel LCD Monitor
Want to replace the vga connector (got a bent pin). Looking for color codes to connect the wires to the right pin number on the db15 vga connector
    Problem Solver:
  • 14 Answers
Want to replace the vga - d885bde.jpg CHeck it out, might be useful for you... Deepak48e8f12.jpg
Posted on Oct 28, 2009
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
My monitor is not displaying red color some...
If only ONE colour is missing - it is usually just the VGA connector that is not plugged in properly or you bent a pin while connecting the monitor to the PC.Unplug the VGA cable and look at the pins and make sure nothing is bent .. then re-insert the VGA connector properly. That should fix it.
Good Luck
Feb 04, 2011 | Computers & Internet
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Prolite e435s iiyama screen
Monitor screens will have color tints when any of pins of the VGA connector is damaged or bent(I assume you are using a 15 pin VGA connection :) ) Please remove the monitor connector cable and check if you have bent or damaged pin at either side of the cable.
If it does not resolves the issue, replace any devices or equipments that may have electro magnetic fields like an UPS from the premises of the monitor.
Also, you can try resetting monitor. All the monitor will have an option for reset in the Menu.
Hope this works!
Good Luck
Mar 09, 2008 | Computers & Internet
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Compaq FP 7020 17" Flat Panel LCD Monitor Logo
264 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
