Question about Rimage Office Equipment & Supplies
When choosing the label, the quickdisc templates does not show
How do I set up my HP 3050 to print Avery labels 5160?
You need to download the templates they have online and edit them in Microsoft Word. Here is a link to the template:
http://www.avery.com/avery/en_us/Templates-&-Software/Templates/Labels/Address-Labels/Address-Label-30-per-sheet_Microsoft-Word.htm
Click the blue download template button and follow the instructions.
Mar 31, 2011 | Office Equipment & Supplies
Which labels for 6310 HP pinter?windows viista progar? 8160labels do not fit 6310 priinter
Vista wouldn't be your problem as your Operating System is unimportant in choosing labels but the program you use to print your labels is very important.
If you Use Microsoft Word, for example, you will need to choose the template for your labels. That number is on the box of labels.
In Word (for Instance) you can do the following:
<File>, <New>, <Templates> (templates are on Left side).
Choose your Type of Label and the Label number from there.
Otherwise, some label companies offer free programs, specifically for printing their labels.
AVERY labels has a free program for printing their label numbers and the Program: AVERY Wizard For microsoft Word is free.
I hope this helps as you do not say which program you use to print Labels and you also do not say which label numbers and/or label type you wish to print.
Thank You For Choosing FixYa~!
Mar 24, 2011 | HP Officejet 6310 All-In-One InkJet...
Desktop out for repairs. Moved 420 label printer to laptop area. Have copy of label file from desktop. Can't get the labels into the laptop printer and it's not in FAQ that I can find. Really need to make...
Microsft Word is probably not only the best but if not the only solution. Test print a label or two, at a time and then a sheet, at a time. Attempting to print muliple sheets from a file associated with a different, standard, printer may not line up well enough to print pages and pages, unattended.
What you see between these ---> < - > <---- Brackets are actions for you to perform.
You'll may wish to choose a Microsft Word Template, you can do that by opening Microsoft Word, <Help>, <Tempates> or (if you cannot find templates) via: http://office.microsoft.com/en-us/templates/ select a label from your file and pick the number from the list that corresponds with the label on the box of labels. Please forgive the ambiguity, I'm working blind without knowing your Operating System or your version of Word, what printer, etc... This is general enough for most systems.
Here's the order:
  1. Click <Tools>, <Letters and Mailings>, Click <Envelopes and Labels>.
  2. Click the <Labels> tab, and Click <Options>.
  3. First choose the printer you want to use and next the label supplier number from the box sheets that you'll print your labels on.
  4. Click <Product Number>, scroll to the corresponding number from the label box. click Ok
  5. Click <Envelopes and Labels>, Click <New Document> and a label document will open.
  6. Type data onto the labels you choose to use, Avery number work well with Word .
  7. Click <File>, Click <Print>.
Now, you could try to make a copy of your label list, to experiment with, but it's probably best that you re-type the labels into each of the boxes while reading from your label program; until your PC is returned
Mar 11, 2011 | Seiko Instruments Smart Label Printer 420...
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
I am trying to print labels and they keep coming out off center
You most likely need to download the proper template from the manufacturer of the labels your using. Look on the package of labels for the web page for them if you don't have the package the company name and template required is usually printed somewhere in the border of the label page. For example Avery avery.com. If the template is not listed you can search the library of templates for one that looks like your labels. Download the template. This should solve your issue of improper centering of the label. Your likely currently trying to use one of the templates supplied by Microsoft, but they rarely work with most labels.
Aug 03, 2009 | Microsoft Windows Vista Ultimate Edition
Dymo 400 laser turbo prints the label then multiple labels after that
This is due to the print template you have chosen.
control panel > printers > right click dymo print icon > properties > press "printing prefrences" in General tab > click "Advanced" button in layout tab
Here you can choose the paper size. The dymo "shipping label" (30573) sold in most office stores is template number is "30323 Shipping".
Also these templates choices are available in the software you are using to print the labels under file -> print setup or whatever your software calls it..maybe "print setup"
Hope this helps.
Jan 21, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
15 people viewed this question
Top Rimage Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
