Closed captioning quit working
I was trying to hook up Lite dvd recorder to the tv and I heard some cracking noise and after that the close captioning won't work. Thank you
  • 837 Answers
HAve you tried just unplugging the TV for at least 5 minutes yet?
Posted on Jan 11, 2009
I am connecting a RCA DVD player (DRC277B) to my TV and have problems when using the HDMI cable. When I connect the unit using the AV Cable, things work OK. I then turned off everything and hooked...
Hi
Thanks for using FixYa. Two things that will cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the not available message. I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts
Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 15, 2010 | RCA Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Turn closed caption off
have 48 inch mitsubishi rear proj tv. Had a power outage and when it came on instucted me to go to reset the clock. I had notice this was not the nomal clock and CC set up menu but had a quite a few items and one was close caption on or off. It was off so I put it on ON and now I have close captioning with every thing even when I go to the regular CC set up and turn it off.
Thanks, Joel Russell
Jun 13, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Recording with closed caption
Carl,
Better late than.. I think that the Polo can record the encoded closed captioning onto the HDD, but you have to have a CC equipped television to display the captioning.
The newer Magnavox and Philips recorders sold at Walmart record the captioning, and have the capability to display it even on sets without the built in CC decoder depending upon your recording settings. If you get a digital converter box and connect that as the source to your Polo, you can record CC displayed on the screen if you want.
tom
Nov 20, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
Closed Captions won't work
make sure your dvd player has the capability to display closed captions, as not all of them do, also if it does have the capabilities, it may need a scart connection.
Jul 02, 2008 | Cyberhome CH-DVD 300 DVD Player
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Closed caption
Throw the damn thing away. And don't even try looking on the internet for the solution. Every link will take you to a sales pitch. Very frustrating.
Feb 04, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
