Question about Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV
Need Instructions to replace D Board in Sony KDP57WS655
D Board Part Number A-1065-548-A needs to be replaced.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Its a picture tube type rear projection---you face several issues here---
1. Finding a good replacement board
2. The D board is to the left as seen from rear.
3. multiple black foldover plugs on one side.
4. multiple plugs to board itself (two groups of 3 identical plugs to make sure you mark to get back exactly where removed.
5. multiple tiny brass screws that secure the board to the black plastic frame.
6. Two red wires from flyback (one fat and one thin) to remove--the thin one goes forward and can be pulled off where it connects and the fat one should have a short run up to the gray or black splitter where you push it in and turn to release it----a few versions require a special tool to remove it at the actual flyback.
When all (mark every plug) are free the board lifts up from front and comes out---common mistakes include not taking all the small screws out.
Lastly it is usually easier to repair than replace this board--you getting any error or blink code from the power light?
Also I have seen a bad convergence chip cause this (should be on same board and stk-392-560) and unsoldering both chips the set will come on----have to be careful there as lots of little surface mounted parts where chips solder in on bottom of board.
As much information as I can think of---let me know if need more help.
Regards, SD TECH
Posted on Dec 03, 2012
2 Suggested Answers
  • 4234 Answers
SOURCE: i need the part number for a replacement lamp for the kp57hw40
I'm sorry to report that the red CRT for this set is no longer available.
Dan
Posted on Feb 27, 2009
Software installation on a brand new sony bravia main board model KDL55W804A
It is very important that you install the firmware as soon as you replace the board. You can download the firmware as well as the instructions for free from the customer support website. Here is the link. Sony eSupport KDL 55HX750 Support . It is very important to follow the instructions as to not ruin your new replacement board. Good luck to you.
Jun 03, 2016 | Sony Televison & Video
Where to buy replacement bulb for Sony KDP57WS655
Looking at the parts diagram I don't think you have any lamp. I think you have 3 CRT's- 1Red,1Blue and 1Green
Link to diagram.at sears parts direct.
SONY Projection Tv Cabinet Parts Model KDP 57WS655
Aug 16, 2014 | Televison & Video
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Cant adjust the convergence in menu colors look ghost,3d looking
You will need to replace the two convergence ICs and then check and possibly replace the pico fuses on the D board and G board. The Sony number one convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains both ICs and the 8 pico fuses plus the CD with detailed repair instructions.
Sep 22, 2011 | Sony KP-51WS510 51" Rear Projection...
Hey I need to know the sony part number for a "Sony Wega KDF-E50A10 power supply block" in order to buy it and replace it. It seems sony doesn't easely gives you that number so you have to send...
Power supply board part number for Sony KDF-E50A10 is as follows:
A1113732A .... GT BOARD COMPLETE
and if you are asking for ballast power supply board part number, it is as under:
146893611 ... POWER SUPPLY BLOCK
Hope these info will help you.
Thanks.
Jan 12, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
My Sony KDP57WS655 standby light blinks 11 times when first turned on. The sound comes on briefly but no picture; then the TV shuts off again. After that the standby light rapidly blinks 10 times, pauses,...
laisecorp,
You have a problem on the "D" board. If you understand electronics and soldering you should check transistor Q8014 and Q8013 for shorts, leakage or bad solder connections. If you find any problems replace the transistors and also check/replace R8051 and IC8005.
If you are not good at soldering or fixing electronics go to http://www.encompass.com and purshase the board, part number A-1065-548-A. The board is $150.00 US plus shipping.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 20, 2010 | Televison & Video
Sony KDF- 42WE655 Blinks 6 times No picture or sound
Thats the error code that indicates the ^v line from the G! board is missing. Replace the G1 board and that should solve your problem. You can get a replacemnet G1 board at the following link, leave them a email with your model number and which board you need and they will respond quickly, as they dont list all the boards they carry, and their boards come with free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Aug 25, 2008 | Televison & Video
9 blinks on my kdp57ws655
Your tv have a G board problem p/n A-1065-549-A( A1065549A).
It local on the leftside of the tv looking from the back,the one has
AC cord attach to it.Sony no longer have it.PTS Electronic rebuild
for $192.00, Ebay Valleysercices rebuild for $69.00
Jul 22, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Convergence on kdp-65ws550
youre looking at about 300.00 for that board if its still available as the entire D board need to be replaced if you go that route. Go to this link as they can get you a prive on a new board or they also sell just the parts and provide free instructions on how to replace the Ics and resistors in the convergence section. heres the link, leave them an email with your model number and what your looking for.
May 26, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV Logo
368 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
