I have an Eror code of E061 on a Canon IR5020 what does that mean
  • 1,326 Answers
A E061 error code is a drum potential problem. You mat have a broken Post corona wire or a broken Grid wire. The problem deals with the main chage corona unit. I would make sure that the unit is installed correctly and make sure none of the charge wires are broken.... It may be a bigger problem, I don't know what has been done... Good Luckl
Posted on Dec 09, 2012
SOURCE: erorr code E061
hola, lamentablemente no tengo respuesta sino mas consultas mi canon Colc 1120 me marca E061 0031
Posted on Jun 09, 2009
  • 56 Answers
SOURCE: eror code
that is a drum problem, change it
Posted on Jun 10, 2009
  • 118 Answers
SOURCE: Error code E061 0093
its a problem of dirty primary assembly or the corona and grid wires are dirty or check your front door actuators if the laser window is not open,laser can't reach the drum and will result Error 061 hope this will help
Posted on Jul 05, 2009
SOURCE: e061
I bought the machine book and I was able to look at it based on him what it reports the E-061 mistakes.
Myself was able to improve it and now good it's working.
I say thank you for your help nicely.
Posted on Jan 07, 2010
Cogz
  • 1326 Answers
SOURCE: hi i am getting E061 0127 on canon clc1000
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Posted on Apr 03, 2010
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Apr 02, 2010 | Canon CLC 1000 Color Copier
Error code E061/0040
check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
Jul 22, 2009 | Canon CLC-700 Copier
Error codes E020/04E0 and E061/0040
Clean the thermistors and the thermofuses the first copier,to second copier vacuum cleaning the suction fan ventilator and ozone filters.
Jul 22, 2009 | Canon CLC 1180 Copier
Jun 08, 2009 | Canon CLC 1180 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
ERROR E061-0122
e061 is a code for a drum charge error on the first drum in line from right to left i think yellow ? any way its either a worn drum broken charge wire if you have not changed drums in a while the other ones may be coding out next
Jan 28, 2009 | Canon CLC 2400 Color Copier
Erorr code E061
Hi
Please my Canon Color Laser Copier is asking me for a code, when i put it on it shows E350 on the table. sir what should i do.
Nov 16, 2008 | Canon CLC-700 Copier
E061
one of your drums is worn is if you repost the sub code i will tell you which drum it is or phone me on 07764303923 if in the uk or 00447764303923 if outside the uk i also have all the tech info on all canon/ricoh models
Thank You
May 28, 2008 | Canon CLC 1000 Color Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
53 people viewed this question
jasbo
jasbo
