Question about Gevalia CM-500 12 Cup Coffee Maker
Will no brew
Green light comes on but the machine will not brew
  • Mildred Simmons Dec 05, 2012
    The green light comes on but the water is not getting hot and pouring into the coffee pot
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
The central unit LED blinks green and the machine does not turn on
Hi
The LED should be blinking red not green on a magic delux. The only green light is the boiler light for warming up or ready. If its the brew unit light it means its missing.
Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 09, 2010 | Saeco Magic De Luxe Espresso Machine
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
