Question about Bunn NHB Coffee Maker
Broke the plate above the funnel -- Bunn NHBX
I had some friends house sit who did not know to slide the funnel out and tried to pull down. Broke the plate that holds it. I glues ita ll back together, but can't figure out how to get the top off so I can connect the hose to the sprayer. There are no visible screw except from the bottom inside. It seems like the top shold just pull off, but it must be screwed on from somewhere
  • DESIGNFARM Mar 13, 2009
    Months ago the same part on my coffeemaker exploded. I have superglued and mended the part several time but it is now in many parts and cannot be fixed.
    Any source for this part would be great.
    Thanks
  • gphineh103 Apr 25, 2009
    Broke the plate above funnel (Bunn NHBX)
  • 189 Answers
The plate inside is not repairable. If you will get the model and date code from the bottom of the brewer and contact customer service, the brewer can be replaced. If the brewer is 3 years old or less, it will be replaced at no cost. If the machine is over 3 years old, it will be replaced at a reduced price.
Posted on May 19, 2010
How to replace warmer plate switch
carefully of course mine I have to remove bottom plate to access it
Mar 15, 2015 | Bunn NHBX-B Generation 10-Cup Home Coffee...
How to fix a Bunn NHBX that produces warm, not hot, coffee?
Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
Mar 02, 2015 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn nhbx leaks water
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Jun 30, 2014 | Bunn NHBX
Bunn nhbx leaks out of the bottom
according to BUNN it is not repairable . they won't sell the parts needed
Jan 19, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
May 12, 2010 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Dont know how to use coffee maker
Hi this is tech crazy
The above link u will get the whereabouts of a coffeemaker and its usage
http://home.howstuffworks.com/coffee-maker3.htm
Kindly do rate me on the above said solution
Feb 03, 2009 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
70 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
