Question about Bernina Sewing Machines
I cant put the inside of my machine back together
I took apart the bobbin/under part of my machine apart to clean it and cant get it back together. what is it supposed to look like???
  • Bernina Master
  • 7,365 Answers
What is the name and model number of the machine ?
do you have a manual?
Posted on Dec 03, 2012
informatica
  • 1114 Answers
SOURCE: putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
SOURCE: putting the bobbin housing back together
Found your problem while I was trying to solve mine. I can solve yours. Here is the page from my manual about how to remove/replace bobbin housing. I hope you can make this image larger so you can see it clearly. We're limited as to the size of the file we can upload.
Posted on Apr 13, 2009
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
  • 13 Answers
SOURCE: i took apart the bobbin part of my kenmore machine
if you look in the well where the bobbin is supposed to go do you see two white pieces of plastic with a red hyphen on them...one on either side? if so, take a small pointed object and pull the red hyphens toward the center of the well. put the assembly back in the machine (it will only go one way, so be gentle. when you get it lined up, it will drop in). then push the two white pieces back away from the center with your finger. drop in the bobbin.
Posted on Mar 05, 2010
  • 980 Answers
SOURCE: white 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
Posted on Apr 10, 2010
Thread breaking
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Feb 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
I cant figure out how to put the bobbin carriage back together on my brother vx1010
I think you're talking about the shuttle and race. It goes together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
Jan 21, 2014 | Brother Sewing Machines
How to put together the bobbin case assembly
Replacing the bobbin case after changing the thread spool gets you back to sewing. The Singer Simple model is designed for the beginning sewer. Even with its simplistic design, often getting started takes a bit of time, concentration and practice. Without the bobbin casing properly in place, the machine will not sew. You can get the machine up and running again.
The little spool holds the thread inside the bobbin casing.
Turn off the power to the machine. Power is not needed for any part of the process. Turn the machine off and unplug for safety reasons.
Turn the hand crank on the machine to move the needle into the highest position. Move the presser foot the up position.
Open the hinged latch covering the front of the bobbin cover. This is the device that holds the spool in place.
Place the threaded spool inside the inner casing. Place in so the thread is running in a clockwise direction.
Slide the thread through the slot opening on the let bottom of the casing. The slot is next to the outer arm of the casing. Close the hinged latch.
Hold the casing so the outer arm is sticking straight up. The thread will be coming out to the left of the arm; lay it under the arm to the right.
Push the casing into the internal bobbin slot on the machine. It will lightly snap into place.
Replace the outer machine cover over the bobbin
May 20, 2012 | Singer 2263 Mechanical Sewing Machine
May 27, 2009 | Singer Sewing Machines
I took my maching apart to clean the lint out and when I put it back to together the needle is hitting the feed dogs. what could be causing this!
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
Feb 23, 2009 | Brother CS-6000
Putting the bobbin housing back together
Feb 18, 2009 | Singer 5062 Mechanical Sewing Machine
Putting the bobbin back together
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
Sewing Machines Logo
80 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
