Question about Panasonic SC-HT441 Theater System
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
The old fan makes noise. Factory fan replacement gives F61 error. System works fine with old noisey fan.
  • Locke Nuttall Dec 04, 2012
    I replaced the original fan with the factory fan. This produces the F61 error. Re-installing the original fan corrects the error and the system functions properly but makes noise. I need to replace the fan without getting error codes.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Posted on Dec 04, 2012
SOURCE: F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Posted on Jan 10, 2008
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
F61 error message
F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, if the power fan or supply is okay then THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH.f61 means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit
Sep 28, 2009 | Panasonic Televison & Video
Keeps showing F61
Panasonic error code F61 is for an output /power problem. Most likely it will need the output ic replaced. But check that the fan(s) are running a bad or stopped fan will also cause F61. Replacing the IC is best left to a technician and Panasonic is the only supplier that I know has the part.
Feb 16, 2009 | Audio Players & Recorders
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Dec 14, 2007 | Panasonic SC-AK300 CD Shelf System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
Panasonic SA-HT740
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
www.pstc.panasonic.com/Epartr/PartsDone.asp
P/N. L6FAJCCH0007 FAN MOTOR (THIS IS THE REAR FAN)
P/N. L6FAYYH0001 FAN UNIT (THIS IS THE SIDE FAN)
Hope this helps
Scott
Sep 16, 2007 | Panasonic SC-HT740 System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Panasonic SC-HT441 Theater System Logo
351 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
