TCl Remote C198A will not work. I've tried new batteries. "Electric eye" does not light up.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Most shops have a remote tester----have it tested (usually free).
Also , most digital camera's in a very dark room will react on the display screen with a flash when the remote is pointed at them and buttons pressed---home check.
If remote is not sending it can usually be fixed---IF remote tests out as good the REMOTE receiver in the unit is bad.
Posted on Dec 03, 2012
  • 1044 Answers
SOURCE: My remote control has stopped
I hope you have done the following other than changing batteries.
Polarity - Check the batteries have been placed properly' Cleaned the terminals as they become ineffective due to moisture and dust. The moisture can come at times from wet hands which some time we do. Hope that liquid/water has not been dropped accidently on the remote which makes the circuit inside the remote ineffective. Blow compressed air inside the remote to clear the dust and moisture inside the remote. If still it does not function there is no other alternative but to replace the older one.
Posted on Oct 31, 2010
Poul_g
  • 97 Answers
SOURCE: my dvd player is not
To make sure the remote works or not. See if it blinks if you shoot the pointy end to a mobile phone in camera mode. If it's working fine there, some other issue. At least you know if it's a battery thing.
Posted on May 08, 2011
walesarumi
  • 6993 Answers
SOURCE: My TV stopped working two days ago. The red
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jun 17, 2011
  • 360 Answers
SOURCE: My TV remote control has
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
Posted on Jul 02, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Remote won't work. Tried new
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Aug 22, 2011
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
Tip
How to see if your remote control is actually working
For remotes which use an IR connection you can see if they are transmitting using this trick. An IR type of remote will have one or two LED's on the front end. If it doesn't, than it may be an RF type of remote - this tip will not work for those.
Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen of whatever the camera is pointing at. Take your remote and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see on the screen. (Cool right?) So, if your remote is working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.)
The LED should light up for every button pressed. If one button doesn't make the LED glow, you may have a bad button - try pressing it firmly. Buttons can wear out. The image of the LED may appear steady or it may pulse or blink on the viewscreen - this is normal.
If the LED doesn't light up, and you know your camera works like this (you've checked a good remote), try new batteries - that solves most problems. Check the battery contacts in the remote - if they're corroded, (white flaky stuff caked on, looks like dried up salt) - you can clean the contacts with a solution of water and baking soda and a Q-Tip. Use a knife to remove any large chunks. Also, some fine sand paper works too. Both the flat contacts and the springs need to be cleaned. Wash any tools (and hands) with soap and water afterwards. Handle corroded batteries as little as possible - or better yet, use gloves.
If you have good batteries and the contacts are clean, and the LED is not lighting up - it's pooched. Try getting a replacement from the manufacturer (call or email/write them), or use a universal remote.
If you've found this tip helpful, please check the box below. =8o)
#Remote #RemoteControl #IRRemote
on Jul 08, 2014 | Televison & Video
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
My remote is no longer working to my insignia 42" tv
First verify whether its an issue with the tv or the remote. If you have a digital camera or a phone with a camera point it towards the front of the remote control when you are hitting a button. a red light should blink. This infrared light can't be seen by the human eye but it can through a camera. If you can see it then it's an issue with the tv which would be more costly to repair. If it's the remote try new batteries or purchase a direct replacement or universal remote.
thank you,
Lee
Aug 22, 2011 | Televison & Video
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
sonsunny
Jul 02, 2011 | Televison & Video
My dvd player is not responding to my remote RMT-D187A the dvd player is fine and will play dvd's but the it's not responding to the remote-I've changed the batteries....there is no way to...
May 08, 2011 | Sony Televison & Video
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
Jan 24, 2011 | Televison & Video
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
