Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Printer hp photosmart 2600 is offline
Reading offline error
    New Friend:
  • 110 Answers
Please download and run the HP Print and Scan Doctor from www.hp.com/go/tools
Posted on Jun 30, 2015
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
SOURCE: Error reading SDHC flash card in a HP Photosmart 8250 printer.
Purchase a SDHC to USB media converter (e.g. SanDisk
M/N SDDR-113-A10M), which allows you to plug that SDHC
memory card into the printer via the USB port.
Posted on Mar 14, 2009
Joed911
  • 4338 Answers
SOURCE: 0xc18a0206 error on hp photosmart printer
Fro our Fixya community:
Try holding down the OK, Cancel, Black, and Color buttons all at once. While holding them down, press the On button to power it off (You may need another person if you lack large, coordinated hands). Turn it back on while still holding the other buttons down. You will notice it turn itself off before "booting" fully. After it turns itself off, you can finally let go of those buttons and turn it back on normally. This will force a reset and system maintenance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 01, 2009
nyilasrobert
  • 627 Answers
SOURCE: Trying to print 'offline'.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Posted on Oct 05, 2009
How to put printer back online
Try the steps listed here. It is a pretty solid troubleshooting guide for a printer showing as offline.
Sep 05, 2012 | HP Office Equipment & Supplies
Why does my printer keep going offline?
The users who are experiencing offline errors while using the HP printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your HP printer.
Feb 28, 2011 | HP Photosmart C4580 All-in-One InkJet...
I have an HP Photosmart 2600 series printer. It is online but is showing offline and I am not able to print anything from it.
please let me know which os u r using and if at the bottom right side of the screen it is detecting the printer or not. please confirm so that i will be able to help u in a better way.
Jan 12, 2011 | HP Photosmart Premium C309A All-In-One...
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP Photosmart 2600/2700 series all-in-one printer problem
Check the expiration date on the cartridge, you may just need a new one. The date is printed on the side of the cartridge. They also just go bad sometimes.
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Solution A:
Solution B:
Solution C:
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 2600/2700/series all-in-one printer error message remove and check printer cartridge on the right when I had been using this cartridge for a while. I have cleaned the cartridge with...
try to reset the HP Photosmart printer, power off, remove the main supply cable, leave it for 30 sec... and restart the printer...below link might be useful for more troubleshooting tips..
http://etech.maiila.com
Nov 01, 2008 | HP Computers & Internet
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
