Question about Garden
My mother in-law has a craftsman 1996 22 inch Lawn Mower, model number 917.377532. Just recently my 18 year old nephew had cleaned the carburetor and replaced the spark plug and primer bulb. It worked for approximately a few hours and now it wont even start, any ideas of what it could be?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
How long has it been since it was running good? Todays gas goes bad very fast.
It may not be the Nephews mechanicals skills that is the problem.
Posted on Dec 11, 2012
  • 109 Answers
SOURCE: Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Posted on Apr 16, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
SOURCE: i have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Posted on Jun 04, 2010
How old is lawn mower model # 917-273481
my parents had a 917.255561. I would guess around 18 or 19 years.
May 20, 2012 | Garden
My mower stops right after I prime the engine like its not getting any fuel. I have cleaned the flywheel, gapped the armature to .013 about the size of a business card. New plug, filter ect. I took the...
Make sure all the small holes that are in the brass bolt that holds the float bowl on the carburetor are clean and clear. Use no metal objects to clean it. You should find holes in the bottom of the bolt and along the top on the non-threaded part. This bolt is also the main jet of the carburetor.
Apr 23, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I try to start my Craftsman Model # 917.388861 lawnmower, it will start and then dies right away, then Iit would start unless I prime it. Before it started doing this, the lawnmower was running very...
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 16, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman briggs and stratton 6.50 190cc lawn mower- wont start unless i pump the bulb. I have a new gas, new air filter, new oil, and new spark plug.any other suggestions?
they were in/out.
May 25, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
My push mower starts but then dies after a few seconds. please help.
they were in/out.
Please rate me, Thanks
May 11, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I can crank my murray gas lawn mower 6.5 quantum
they were in/out.
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My lawn mower just quit running it is two years .Ino it is a fuel problem but what /
If you KNOW FOR A FACT that it is a fuel problem you might try removing and cleaning the carburetor float bowl and the main jet in the carburetor.
I can't offer much advice when you don't specify what engine it has or what is the model number of the mower.
There are as many or more different combinations in lawnmowers as there are in cars thus we need to know more information when you ask for assistance or we just have to guess!
Oct 04, 2009 | Craftsman Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
