Question about Lexmark X5070 InkJet Printer
Lexmarkx5070 fax can this be used without ever using the fax
    Novelist:
  • 180 Answers
Sure! Just because a feature is available doesn't mean you have to use it. This would be just an available feature if you absolutely need to fax something that can't be emailed.
Thanks for using Fixya.com and please rate this accordingly.
Posted on Jan 11, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Feb 05, 2010 | Office Equipment & Supplies
Unable to receive fax without picking up hand set - any pointers? We have the setting to Auto
CHECK THE CABLE IS IN THE CORRECT SOCKET AT THE BACK THE CABLE NEEDS TO BE PUT IN THE LINE SOCKET NOT THE TEL SOCKET AND ALSO MAKE SURE THE RX OR RECEIVE MODE IS SET TO FAX MODE IF IT IS JUST A FAX LINE OR TEL FAX MODE FOR USE WITH PHONE.. THE TROUBLE IS USUALY WHEN YOU ARE USING THE FAX ON A LINE USED FOR TEL USE AS WELL..__
Aug 05, 2009 | HP 1040 Plain Paper Inkjet Fax
Unable to send faxes with HP Officejet 7310xi All-in-One
Fax machines are analog devices and will not work reliably on a digital phone system.
Mar 15, 2009 | Office Equipment & Supplies
Lostmanuaellexmarkx5070printerneedtochangeincartage
Removing a used print cartridge
Make sure the printer is on.
2 Pull the control panel up.
3 Raise the cartridge access door.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
4 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
5 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat steps 4 and 5 for the second cartridge.
If this helps you plz rate this. Thank you kindly.
Jan 30, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I have lost my driver for lexmarkx5070 can i download a free one
I have lost my driver for lexmarkx5070 can I download a free one
Sep 08, 2008 | Lexmark X5070 InkJet Printer
FAX
Where you able to scan and make copy without any problem...?
You can try a Partial reset which would reset the printer for any errors, Partial reset is: Unplug the power cord from the printers end with the power still on, and then press and hold the # and No 3 Keys in the All-In-One and insert the power cord without releasing the keys, it will display in the screen as partial reset
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Can I use the fax and phone on the brothers printer without hooking it to my computer, just to the phone line?
not knowing the model of the printer there is no definitive answer
but
a printer/fax with a fax scanning unit built in can be used as a standalone fax
Jun 28, 2008 | Brother Office Equipment & Supplies
PC faxing
you have to install the mfl-pro suite given to you by cd. After installation go to START/PROGRAMM/BROTHER/PC-FAX SETUP (Guess you run windows). Or simply use the paperport software: drag your document and drop it to the faxsymbol. If you dont have it, download (153mb) from brother homepage of your country. Pleas notice: the faxprinter of xp wont work anymore after installation of the brother drivers (but you have the bro drivers then installed for fax :) )
Oct 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark X5070 InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
