I have a Phillips Fla screen and a few days ago it started making this loud buzzing/hissing sound that somewhat goes away once the TV is on but comes back with a vengeance when we turn the TV back on i have even unplugged the TV from the wall and the noise is still there, can someone kindly help me please?? I really don't have the money to replace it with a brand new one right now
  • 1 more comment
  • Lindsay Dec 03, 2012
    Is this an expensive fix do you know???
  • SD Tech
    SD Tech Dec 03, 2012
    it depends on if a board has to be replaced or not---sometimes a part will vibrate on the power board making a sound--seen several where once pinpointed to a single part (usually a small transformer or coil) hot glue can stop the sound.
    Thank You So Much!!!
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Most likely if a buzzing or similar sound that is there even with set off--you have a noise coming from a transformer in the standby power supply which is running all the time if the set is plugged in----
Someone would have to open set and listen for it---either a part, a board, or hot glue would have to be used to mute the vibration that is making the sound----one way we locate is with cover off probe with a plastic tool to see where it is.
If you are not able to do this have a tech or a shop "look" for it.
Posted on Dec 03, 2012
    Is this an expensive problem to fix by chance??
tvtek
  • 1284 Answers
SOURCE: buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Posted on Nov 27, 2007
redhead7377
  • 51 Answers
SOURCE: buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Posted on Sep 09, 2008
SOURCE: Plazma TV buzzing noise
The transformer is resonating. Get it replaced, Don't do it yourself.
Posted on Sep 27, 2008
Highdefjeff
  • 124 Answers
SOURCE: Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: TV won't turn on.
The YouTube video was correct solution for me, i went to Radioshack and bought two (2) 1000uF capacitors 35 wv part#272-1032. I already had all the soldering tools, i used a desoldering wick and my suction tool, the suction tool worked better. after installing the caps, put the board back into TV and turned it on.. all is well so far. i paid $3.44 for the parts. even if you have to buy a tube of solder, solder iron (15 watt max), and de-soldering tool it's still cheaper then repair shop and got nothing to lose even if you are a novice with soldering. :) Good Luck and thanks you guys for the lead on fixing my TV issue!!!
Posted on Aug 04, 2009
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Polaroid 37 in LCD TV
combination of loss of your power supply and blown resistors take it to a shop
Aug 30, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Hissing sound when turned on and goes dark when sound stops.
takes long time for tv to come on, there is a loud buzzing sound and poping noise
Mar 16, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Buzzing sound coming from speakers
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
