Question about Fisher and Paykel Fisher & Paykel Washer
Fisher &Paykel washer will not rinse or spin. All lights are on.
WA37T26G washer
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
There are eight light I think. Are all of them lit?
Posted on Dec 03, 2012
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
IFIXALL
  • 868 Answers
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Posted on May 25, 2008
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Posted on Sep 07, 2008
Krazytech
  • 725 Answers
SOURCE: my fisher and paykel smartdrive
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Posted on Dec 15, 2008
Why is the washer Full of water but won't power on?
It sounds like the pump has went bad & also taken out the main board.
Common fault is pump.
May 10, 2014 | Fisher and Paykel WA37T26G Top Load Washer
Machine won't turn on
That sounds like the pump is jammed and did not pump all the water out.
May 10, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher-paykel washer fills on final spin cycle
Does your machine have a diverter valve,
If it does the valve is stuck in recirculate mode.
Lint has jammed it closed.
Feb 07, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Our fisher and pykel always off balance( wont spin at all because of it)disconnect unbalance sensor?
Try to raise your back feet on the washer, so that it tilts forword away from the unbalanced censer
but not to much,or it will bang on the front. Hope this helps
Oct 18, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't spin, keeps giving unbalanced alert
You probably have a faulty Out of Balance Switch.This is a little micro switch inside the control box underneath the main computer module,right hand side.You will need to remove the modle to get to it.
May 31, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't drain
Check the motor coupling to pump, see if it's torn up. If it looks ok try to spin it with your fingers. If the pump shaft will not turn, take the pump off and see if lint, rags, pocket change or something has it stalled.
Jul 28, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
