Question about Dell Inspiron 1501 Notebook
Picture ok but no sound from tv when I connect laptop to tv via HDMI. Any help?
No matter how I play with the audio settings I can not get the Dell audio to come from the TV when I connect via HDMI cable. The screen is fine - just no audio. The audio continues to play from the computer. Any ideas?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Simple fix : Click start and type sound and goto "change sound card settings"-> goto HDMI sound (tv icon) and right click it -> select "Set as default" It will work. Just restart the application from which you are trying to play the audio. It will work 1000%
Posted on Oct 21, 2013
Screwy1010
  • 10 Answers
SOURCE: Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Posted on Dec 31, 2008
  • 166 Answers
SOURCE: Connect Laptop HDMI to Receiver to TV via SVIDEO
you need a different type of cable to connect to your tv.a s-video will fit but not work.can't remember the name but it has to have more pins.besides that port is for projectors and cannot be used for anything else.you need a converter box like the one in the link ::::: http://www.bing.com/images/search?q=laptops+s-video+cords&FORM=BIFD#focal=a85da1a40c404788d7e32f0bf01eab05&furl=http%3A%2F%2Fwww.cvs.k12.mi.us%2Ftiz%2Fimages%2Fsvid-cables.jpg
unless you got a big tv with a very good picture it isn't worth it.and a good graphics card in the comp.most tvs are fuzzy and unreadable.i've did it enough to know
Posted on Aug 05, 2009
  • 126 Answers
SOURCE: Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: No picture when i connect to tv via hdmi
If you can give me some more detail, I might be able to help. Are you trying to connect your computer to your TV? If that is the case, most graphic cards can be set for dual output, but in most cases this has to be enabled through the software that came with your graphics card or by going to the properties screen on your computer monitor. There are several ways to do it. Hope this helps
Posted on Oct 05, 2009
  • 50 Answers
SOURCE: I connected my DELL MINI Inspirion 10 via HDMI to LCD TV
Hi
HDMI is only used for Video output and not for sound, you will have to use your laptop audio out (has a pic of headphones), you are able to get headphone jack to phono (white / Red) cable to connect to TV or surround sound system or your laptop speakers.
Regards
David
Posted on Dec 30, 2009
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
Dell insperon 1525 no sound or picture to tv with new hdmi cable connected , it worked fine yesterday but now i can get nothing , it doesnt even show on the tv that the laptop is connected to the tv
When you connect the laptop to the tv with the HDMI cable you will need to press function and F1/F2 depending on your keyboard layout. It is the key with 2 screens on it.
Once you press that windows will show you options for changing displays like Duplicate, Extend, Monitor, Projector(in this case Projector is the TV)
And for audio, you will need to right click on the volume mixer in the system tray and say playback devices. Click on the hdmi one and say set as default.
When this is done, everytime you plug in the HDMI to the TV it will automatically play audio from the TV.
Mar 02, 2011 | Dell Inspiron 1525 Laptop
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
I connected my DELL MINI Inspirion 10 via HDMI to LCD TV. have a good pic, but haven any sound (can play movie, but nothing voice). Check everything, no find problem. Can u help me?
Hi
Regards
David
Dec 30, 2009 | Dell Inspiron Mini 10 Notebook
Connected my x1300 to my tv via hdmi got picture but no sound. lead works and nothing is muted. plz help
Sound doesn't travel to you tv via a hdmi lead from your laptop, you would need to use laptops speakers, or a connect the laptop to a suitable audio device.
Nov 22, 2009 | Acer Computers & Internet
No sound on hdtv when hook up to hdmi
hi buddy u have to change ur sound setting from the Control panel.
ie by default the Sound is played through ur default sound card.but if ur using ur HDMI connection then u have to chage it frm control panel
Steps:Control panel>Sound N Audio Device>Click on the Audio TAB(the Third on frm the top_)>there u will find an option Sound played back and u will have Drop down option once u have connected the HDMI.afer u have selected the option click on apply>ok.then U will definatly get Sound frm ur TV.
May 26, 2009 | HP Televison & Video
HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Dec 27, 2007 | Sony QUALIA 005 46 in. LCD Television
Dell Inspiron 1501 Notebook Logo
230 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
