Question about Garden
Mtd engage blades it smokes and make noise
Hello- Just received a MTD lawn mower/tractor 42 inch with the bagger. Just put a new battery in and cranks runs good. When i go to engage the blade, the front fills with smoke and smells like burning rubber/makes a winney noise, and then i disengage...any ideas, belts are on, seem a bit loose, but im not sure they should be ultra tight
    Scholar:
  • 61 Answers
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Posted on Dec 03, 2012
  • matthew s Dec 04, 2012
    Thanks Rick, I tried to move the blades and was not successful, the mower was sitting outside for 2 years under a cover, but i no the belt is loose as well.. but perhaps i can try to free up the blades first..thanks a billion
  • Rick Dec 06, 2012
    Matthew i hope your lucky enough to be able to free the blade spindle, somestyle spindles will have a grease fitting either on the sidoof the spindle housing or it may be on the top of the spindles drive belt pulley if you can get some grease in with a grease gun you might get lucky and free it up however if it feels rough or course sounding you're probably going to need to change them
  • 3 Answers
Ajustement des valves pour moteur briggs stratton 16.5hhp model 313777 0112e1
Posted on Jul 10, 2014
2 Suggested Answers
  • 11 Answers
SOURCE: I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Posted on Jul 11, 2012
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
MTD 42 INCH DRIVE BELT DIAGRAM
Go to MTD website and download the manual for your machine.
Jun 19, 2014 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd hydrostatic lawn tractor blades will not engage
mtd makes a hydraulic driven mower blade what's it's model number ?
May 13, 2014 | Mtd Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Jul 11, 2012 | Garden
MTD J/130
check the oil and see if it smells like gas if so the needle valve in the carb is bad
May 09, 2012 | Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Deck belt does not engage blades on riding tractor
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 18, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
246 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
