Question about Epson Stylus Photo T50 Inkjet Printer - Color - Photo Print - Desktop
Epson t50 printer both light green & red are permanently on
munnabhai
SOURCE: Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Posted on Sep 21, 2008
jacklee366
  • 541 Answers
SOURCE: EPSON R230 PRINTER IN INDIA BOTH RED LIGHT FLASING. PLS HELP ME
hold down all 3 bottons to reset it or download the ssc
Posted on Jan 27, 2009
  • 700 Answers
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
Posted on May 25, 2009
  • 5603 Answers
SOURCE: My Epson Stylus T10 Printer have a problem...it
The waste ink pad needs to be replaced or cleaned AND the service software used to reset the internal counter. You cn download tthis online.
You have to dis-assemble the printer to get at the pad. You can clean the pad with agressive rinsing till it is a very light gray color. (A lot of ink will be flushed out!)
Posted on Oct 23, 2009
cns assoc
  • 677 Answers
SOURCE: epson stylus T10 printer stopped working
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Mar 19, 2010
Printer epson t60 the red light are always transferring to sides
you need to reset waste ink pad counter by adjustment program for epson t50 t60 printers
Mar 27, 2015 | Epson STYLUS PHOTO T60 INKJET PRINTER
Blinking 2 led lights
I have a new Epson T50 Printer, it blinks two red lights whenever I try to print, what is the solution for that
Jun 04, 2013 | Epson T50 InkJet Printer
Epson t30 reset
For every one who say resetter Epson T11, Epson T30, Epson T33, Epson T50 and Epson T60, now resetter for these epson printers getable for download here. All of the software not creation software beause the software has roughened by OrTHoTaMiNe. All software resetter functions exclusive to set ruin ink tabulator.
The Resetter Epson T11, this software make also for epson T10. Resetter Epson T30, there two variant software resetter, One of the software product on Epson T33. There are triplet version of resetter epson T50 and Resetter Epson T60 exclusive available one type.
Jul 28, 2012 | EPSON Stylus Office T30 Series
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Epson tx121 two red light and green light blinking
HOW TO SOLVE THE GREEN & BLUE LIGHT STILL BLINKING
Mar 06, 2011 | Computers & Internet
My Epson t50 do,t print & two red light are blanking
I have also epson t50 and same problem.Its two red light blanking means you can reset the waste ink pad counter .
Here i upload epson resetter program you can download it and open the floder working one.
http://rapidshare.com/files/438531224/Epson_T50_All.rar
Dec 11, 2010 | Office Equipment & Supplies
Epson t30 , 2 red lights on ,printer no working . how to fix this
Hi!
Maybe waste ink counter needs to be reset.
Download the resetter from the link below and follow the instructions carefully.
Download Here:
http://tricks-collections.com/download-link-resetter-epson-t11-t30-t33-t50-t60/
Reset and Reboot
Nov 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
I had purchased printer Epson 230X with external ink box when I operate the printer it doesn't work the ink cartridge does not run to and fro both red & green lights are on can we fix it
Jun 15, 2010 | Epson STYLUS R230 InkJet Photo Printer
Green and red light permanantly on.
Green and red light on : ink out error / chip doesn't recognized. If u use SSC, and said "Coomuniaction error", it's normal. Replace ink tank, or use CISS chip.
Jun 11, 2009 | Epson Stylus 680 InkJet Color Printer
Epson Stylus Photo T50 Inkjet Printer - Color - Photo Print - Desktop Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
