Question about Cuisinart DCC-1200 Coffee Maker
The red brew light comes on but will not brew about 3 years old
Never had a problem before
Amazing! My dcc-1200 developed the identical problem on the identical day. Sounds like planned obsolescence. I will watch this space for solutions. Sorry I can't help; I'm frantically looking for my receipt.
Posted on Dec 04, 2012
  • cjperretta Dec 05, 2012
    Called Cuisinart customer service. I am still under warranty, but was advised to: 1. unplug at least one hour, 2. remove deionizing filter from brewer, 3.While still unplugged, add 6 cups water and 6 cups distilled vinegar, allow to sit unplugged for at least one hour, 4. Plug in and brew as usual. The mineral build-up can apparently prevent the mechanism from working. I will report on success or failure.
  • cjperretta Jan 29, 2013
    The vinegar solution did not work. I called back and was asked to read off the serial number embossed into the bottom of my brewer. This apparently gives them the approximate date of manufacture. I was informed that my unit was still covered by the warranty, and that they would ship me a new unit. I believe I had to pay shipping. The new unit arrived as promised.
Red light comes on but coffee doesn't brew
If there is a thin water line in your coffee maker, then it can get clogged or could have mineral build up. Keurig coffee maker, you are going to want to descale it every 6 months. Calcium can build up.You need to run a large cup of white vinegar through coffee maker lines. When you run vinegar through there, the coffee will taste nasty, so I would run water in there several times, after the vinegar finishes. Run through until does not taste nasty anymore. Yeah, I do this with my coffee pot 3 times a year. You judge how often you should.
Good luck.
Sep 06, 2012 | Cuisinart DCC-1200 Coffee Maker
Beeping sound, won't brew
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    Feb 15, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
    My brew group was stuck, followed instructions and got it out and motor turned to correct position. Put it back together and now nothing...green light comes on and thats it. No motor sound, that's i
    Unfortunately I cannot locate your problem or duplicate it. The various units that turn on the red "stop" light are the grounds container, the drip tray and the brew group. When they are reinstalled the light goes out . So if your brew group was stuck and you had to force it out then you should check very carefully that there are no cracks or breaks on the back. Remember this, the brew group must "click" into place and lock so that it does not move in and out unless the "Press" button is depressed. It is possible that one of the above switches that signals the motor to start is stuck, even if the red light is out, and not allowing the motor to turn on. I don't see the reason why your brew group was stuck to begin with. How did that happen?
    Nov 19, 2011 | Saeco Vienna De Luxe Espresso Machine
    My < year old DeLonghi
    If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
    Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
    My 6 to 7 year old Silvia stopper making steam today. Do I need to send it out and where or is a diy
    If it comes up to brew temperature, you have to replace the steam thermostat, which is a DIY. There are 2 thermostats on top of the boiler. The one with the red dot is the brew thermostat, so the other one is the one you need to replace.
    Aug 22, 2010 | Rancilio Silvia Espresso Machine
    We have a 2 year old Cuisinart COD 4000 series. The unit will no longer starts. We put on brew cycle and turn knob to on. Light comes on. Hear a click but it does not brew anymore. Have unplugged unit...
    I just had the same exact issue, call cuisinart customer service and they'll replace it. The unit has a 3 year warranty, I had no receipt or anything and they are sending a new unit, all they ask is that I cut the power cord off of the old one and send it in.
    Aug 07, 2010 | Cuisinart Programmable 12-cup Thermal...
    3 red lights box under 3 years old
    RED LIGHT OF DEATH!
    The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 motherboard or power supply.You can test power supply with a voltmeter from power supply wires to the connections on the motherboard. If no power or low power, the supply is bad. If there is plenty of power, then motherboard could have bad capacitor or chipset on it causing the problems. You can test those with an ohmmeter to see which component is not the same.
    Nov 23, 2009 | Microsoft Xbox 360 Console
    Bloomfield 3-pot coffee maker won't brew
    These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
    Nov 18, 2008 | Bloomfield 8571 Coffee Maker
    Flashing red light
    Just found the answer!
    The type 453 coffee maker offers a carafe ‘pre-warm’ function.
    This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
    To toggle this feature, push the top-right button in the control panel until the display reads "off".
    Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
    Cuisinart DCC-1200 Coffee Maker Logo
    388 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
