How to find error codes on fisher & paykel wa37t26g washer
Lights on control panel remain on but the unit will not rinse or spin.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Here are the error codes.
Posted on Dec 03, 2012
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
  • 3 Answers
SOURCE: fisher & paykel smartdrive MW095AU wont spin
Does the pump empty the machine, if not you may have a faulty pump, these have no protection againt water coming from above and regularly fail
Posted on Feb 09, 2009
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't empty and spin
You either have a blocked water pump or more likely a blocked diverter valve. Easy to fix if you are handy. Tip machine back on a 45 degree angle and let rest against the wall. It is a matter of disconnecting a coupe of clamps and twisting the pump counter clockwise.
Dec 25, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
My Fisher & Paykel WA37T26G is Having problems... It will not agitate rinse or spin.... I can get it to drain But it stops after about 5 seconds and then I have to wait a few minutes to see If I can...
Hi just read your posting.Now is your machine an Aqua smart model?Does the pump you touched have a fan attached to it?When the machine stops does it beep and show an error code?Problem could be the pump but please reply with answers to the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 02, 2011 | Fisher and Paykel WA37T26G Top Load Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
