Question about Dometic Refrigerators
I have a Dometic Americana Refridgerator #2551, the problem is the vent on top of the camper cracked an blew off on the way to a camping destination (and it was raining) so when we got the camper set up we put a plastic bag over the vent on top of the camper to keep the rain out. Not thinking we left the refridgerator on over night. The next morning the refridgerator was hot inside and i realized then that i had closed the vent off and it was not getting air. The check light came on and it had blown the 5 amp fuse on the control board. We tested the heating element and the board and it appeared the element was burnt out but the board was fine. Replaced the element, the check light went out and it is not blowing the 5 amp fuse anymore but the fridge still will not cool. Any suggestions?
    Top Expert:
  • Dometic Master
  • 5,706 Answers
Replace stack fusible link or red wired fusible link
Posted on Jun 18, 2016
catriver
  • 878 Answers
SOURCE: Freezer works fine refridgerator does not
anan, I think your display is giving you a code on these LG. See if you can find the tech sheet behind the toe panel. On your display panel from memory, 3 led's lit from the left means a failed defrost thermistor. This could be the reason you are frosting up and restricting the air flow. There is a main board in back that you can ohm out the thermistors. Connector 4, the two bright orange wires #5 and 6, should ohm at 19K ohms at 50 degrees. Now Im doing this from memory, if you can find your tech sheet, it will give you precise information. Catriver.
Posted on Jun 14, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire model FRT16CRH. Top freezer not getting
Your refrigerator has a defrost timer and it may not be going into defrost every 8 to 10 hours. I was not able to get a picture for you of the location, but look inside the fresh food compartment and inside the teperature control panel should have a hole with sometimes a plastic plug stuck in it. If not there it will be under the kick plate at bottom of fridge. Take a flat head screwdriver and slowly turn to the right until refrigerator stops running. After about 30 minutes if it does not restart, star by again turning slowly clockwise until it starts. Let me know what you find, Thanks, Sea Breeze
Posted on May 18, 2009
  • 122 Answers
SOURCE: Dometic 2551 Americana. Nothing.
replace your lower circut board
Posted on Jun 05, 2009
Greg20
  • 149 Answers
SOURCE: my Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Posted on Jun 14, 2009
reyjoshua07
  • 1157 Answers
SOURCE: I have a Dometic RM2601
Hi rquiett,
If it does not cool on either gas or electricity but is getting hot at the rear of the unit chances are that the cooling unit will need factory repair or replacing. There are only two main failures with gas RV refrigerators.
1 The RV refrigerator is run unleveled causing the cooling unit boiler to overhead, block and crack.
2 The RV refrigerator cooling unit's steel tubing rusts and the ammonia/hydrogen gas leaks out.
Gas RV refrigerators do not operate the same way as other refrigerator types. They are charged with four types of chemicals and this mixture must be exact for the unit to work properly. The four chemicals of the charge are.
1. Water
2. Ammonia Gas
3. Hydrogen Gas
4. Rust Inhibitor powder
Boiler blocks or cracks - If the refrigerator is run while not leveled for an extended period, the cooling unit water will not flow into the boiler. The boiler as a result gets excessively hot and can bake the rust inhibitor. This will in-turn block the small 1/4" tube in the boiler and all flow will stop. If the refrigerator is kept running under these circumstances the boiler tube will get so hot that it will crack open. If this happens a yellow powder around the burner area may be visible indicating that the cooling units rust inhibitor is leaking.
Leaks - When a unit rusts and leaks as a result, the ammonia gas is lost first. You can sometimes smell the ammonia gas. However when the door is opened or if the leak is small there can be little or no smell. Under these circumstances there could be a boiling sound at the back of the refrigerator. This means the hydrogen gas has also leaked out and the water is now boiling. Ammonia smells or large gurgling sounds from the refrigerator are indicators that the refrigerator cooling unit is leaking.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 25, 2011
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Why is my refridgerator not cooling?
unplug thermistor if doesn't cool over nite bad cooling unit of ok bad thermistor
Jun 04, 2014 | Dometic DM2862 Americana Plus Fridge...
Our Dometic refridgerator in our 1992 camper
I would start there before replacing any parts. The circuit boards require 12volts to operate the refrigerator. If you have a good 12 volts and the LP tanks are full and the flame lights but the unit does not cool then you probably have a bad cooling unit. But start with the obvious issues first.
Sep 03, 2013 | Dometic RM2620 Refrigerator
Can not get new refrigerator into lance camper.
Opening wrong size? Please, more details on what problem is.
Sep 01, 2013 | Dometic RM2554 Americana Fridge...
Dm2652
if Lp system is ok replace board but check gas line for obstructions if no clicking noise bad board or ignitor
May 30, 2013 | Dometic DM2652 Americana Fridge...
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
Looking for air vents for dometic 150 lt fridge
Dometic part numbers:
Upper side vent 8030211.331
Lower side vent 8030211.332
available at most RV dealers and camping stores
I would download the user's manual from the dometic website, it's very helpful
Sep 10, 2010 | Dometic RM2193 Compact Refrigerator With...
Refrigerators Logo
42 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
