Question about Ovens
H5040BP miele oven door locked and no power after prolytic clean
After resolving the door issue on one of my ovens (with the help of Fixya) I decided to clean my other oven using the pyrolytic function. It's a Miele H5040BP compact oven with two 'push-in' control knobs with a digital display and touch buttons in-between. All went well for 2 hours then I noticed that the digital display had turned a dull orange as opposed to the usual bright orange. Whilst I was wonderering how to proceed, it turned off on its own accord. Then I realised that there was no power to it at all. I checked the fuse box, RCD hadn't tripped, all seemed fine there. I switched the oven off at the isolator switch for a while, but on switching back on there is still no power. I suspect that something might have burnt out at the point of connection and want to remove the oven to inspect the back. However, it's a bult-in oven with fixings behind the oven door. Thing is, the door is locked so that I can't get the oven out. Any ideas on how to manually release the door lock? I can't belive Miele wouldn't provide a manual over-ride (probably hidden somewhere). Any ideas please?
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
  • 177 Answers
SOURCE: miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Posted on Mar 19, 2010
  • 57 Answers
SOURCE: When I was using main
Sounds to me to me like a direct short. Hot wire in unit could be touching part of unit. Oven switch if it has one or main board could be shorted. Oven will have to be pulled to check. Slimm possibility weak breaker.
Posted on Mar 02, 2011
mickeyboy200
  • 39 Answers
SOURCE: Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Posted on Sep 05, 2012
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
While upper oven cooking the door will lock and f9 appears. what would cause this?
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | GE Profile JT952 Electric Double Oven
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Miele pyrolytic oven: error 90
Mar 14, 2010 | Miele DG 4080 Stainless Steel Electric...
I used the self clean feature and now the lock is locked, but the oven door cannot close because the lock mechanism is latched but the door is open...??What to do?
Hi
Thanks for using FixYa. From what you have described it seems that you'll need to replace the complete door lock assembly.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Jan 13, 2010 | Ovens
Door remains locked
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door locked.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Ovens Logo
79 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
