Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
Posted on Dec 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water not spinning out - Whirlpool LTE5243DQ Combination Washer/Electric Dryer
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Dec 03, 2012
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628987
Points
28464
What is the complete model number?
2answers
My Lg too load washer sprays water during spin cycle
It is normal for a washer to spin and spray fresh water over the clothes during rinse period. I don’t know why it would leave clothes wet. Look at your options. See if you can turn off rinse n spin to just spin.
1helpful
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
1helpful
Washer will not spin water out
There is a flap inside of the washer that comes up as the washer begins to spin...Just replace that valve and everything should be fine. As long as its spinning and washing you will not need to get a new one :)
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
13helpful
5answers
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
