F 21 problem
The machine can not start, it keep flashing F 21 when switched on,
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
TEC 21 SL calibration
I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
Feb 15, 2012 | Taylor 5757 Digital Glass Body Fat Scale
No what should i do know, don't have tool scanner
Try turning ignition switch thre times, without start engine ( ON / Off / ON / Off / ON ) and count the blinks light two short means a 2, space and one short flash measn 1, so code 21.
Keep us updated.
Oct 15, 2011 | 1994 Plymouth Voyager
My furnace is flashing 21 green and then it flashes red ...the furance will not run . I have replaced the thermostat and cleaned tha condensate drain
not sure what 21 is ,but if you are getting acode normally the code comments are on the door or the manufacture lable to tell you what they are...
i can tell you the operation and maybe that will help you out...
the unit should start off with the enducer draft motor small motor in furnace that pulls all the stale air out..then the negative pressure switch activates which should have a hose coming from the enducer draft moto to the pressure switch..once the pressure switch closes it sends power to the ignitor and the ignitor should glow once it gets hot a milivolt current is sent back to the gas valve and it opens up and fires...after it fires you should have a flame sensor small metal rod in the direct path of flame that keep sensing the flame and sends signal back to board.... unplug unit and watch it start where is it failing or in what part of the operation does it flash a code....
Jan 03, 2011 | American Standard Heating & Cooling
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HE 2plus problem
Hello, the F-21 blinking is an indication has a too long of a drain out condition, and what actually cause these is when the control call for the unit to drain and the water does not drain out in 8 minutes or less the unit will stop and flash F-21. So try checking the drain pump and pressure switch circuit.
Thanks
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
