My computer (Sony FW Series Notebook) is not getting any communication with the Lexmark P3150 printer.I have loaded the driver software Lexmark 3100 series. Usb cable seems to be ok.Please help. thank you.
Download the P3150 driver that matched your windows version from
below:.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to print a document again to
verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ieDcBl. Select your operating system, download and execute the file.
It won't print
