All led are on in my router - Computers & Internet
  • 7,627 Answers
And your question.............is?
Posted on Dec 03, 2012
I am having a DIR 600L router i was using it and it have sudden disconected to my network and no led are working only power button is shown led
Well it may be due to some problem so
check your router and modem.
check your router setting according to your ISP.
check your firewall setting for blocking network.
Try to update your Firmware.
If still not working than reset your router and configure again. if all of this will not work than contact to http://support.dlink.com/index.aspx
and D-Link Router Support for more technical help.
May 24, 2014 | D-Link DIR-600 Router
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
We are using WGR614 V8 Netgear Router it was working fine but one day after putting power switch on front panel of Router Power indicator LED and wireless LED are not glowing but Test LED, internet LED and...
no it never needs a hard ware repair... doing a hard reset for the router will help... press and hold the reset button on the router for 10 to secs using a paper clip or any safety pin.... reconfigure the router when reset is done completely...
Dec 13, 2010 | NetGear WGR614 Wireless Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
DLink WBR-2310 freezes up with all four of the LAN ports lighted up along with the WAN LED and the power LED....the status LED and the WLAN LED are not on....router is just frozen and reset button does not...
If all lights are lit regardless of anything connected then you may have a hardware failure. Try a hard reset by putting a tip of a paperclip into the small reset hole while powered on for 10 seconds. See if that resets you router - if not then it is dead.
Nov 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
No wireless signal from the router, overheating
its not desirable that the router should get Hot. Only suggestion is you can go in for a replacement
May 31, 2010 | Linksys WRT160N Wireless Router
The STATUS led on my D-Link DI 524 wireless router
reset you router on factory set and then you can see the satus of lights.
Apr 04, 2010 | D-Link DI 514 Wireless Router (DI-514)
Failed update firmware, on router asus wl600g, when router is on de power led parapadea
try reset (press reset buton more than 5 sec, until all leds is off , and power led is red). release button . if power led is allways red, u dont have any firmware on router. and contact dlink to repair (dont say u update the firware, or they charge a new one).
Dec 26, 2009 | ASUS WL-600g Wireless Router
Router WRT54G no Power led on
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
Jan 03, 2009 | Linksys Wireless-G WRT54G Router
LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Jul 05, 2008 | D-Link DI-704P Router
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
