Question about Metra 2000 Chevy Tracker/Metro/Prism
Acceleration Intermittent loss of power while accelerating. Misfire sound at higher RPM.
    Sergeant:
  • 256 Answers
Was the car ever tune up?
Posted on Dec 04, 2012
  • Jeff Kelley Jan 05, 2013
    Yes. New plugs, cam shaft sensor and o2 sensors, both. Seems to only happen in gear. Shift to nuetral and it revs like normal.
Tip
Loss in engine power, sluggish responses, low top speed, etc.
If your car has
  1. Poor fuel responses
  2. Lost its "power"
  3. Low RPM
  4. Lower top speed
  5. Burns a lot of fuel
Then it could be because of carbon build-ups in your engine's combustion chamber. This is left behind with unburned fuel. It causes poor acceleration, a loss in power, lower top speed, and burns more fuel than it really has too. Not to mention causes smoke belching.
The best way to get rid of that would be to have a carbon ridding solution injected into the combustion chamber. The solution will liquify the carbon and other build-ups, which would then restore the "power" of your car. You'll get better acceleration, higher rpm and top speed, save fuel, etc. have a mechanic do it for you. It's alot cheaper and faster than having the engine overhauled (overhaul could trigger "loose compression").
on Aug 08, 2008 | 1995 Toyota Camry
Tip
Restoring Car's Power And Saving Fuel At The Same Time
If your car has
  2. Lost its "power"
  3. Low RPM
  4. Lower top speed
on Aug 08, 2008 | 2001 Honda Civic
When I start my 1996 Honda accord the engine seems to sputter rpm gauge revs up on its own and spits and sputters as I'm driving down the road
My sputtering & stalling 1993 Honda Accord - YouTube
? 2:12
https://www.youtube.com/watch?v=Ki2H9aq8Xis
Jun 23, 2011 - Uploaded by mdpbfly
My sputtering & stalling 1993 Honda Accord ... 1996 Acura Integra, hesitation accelerating & misfire. ... 1993 Honda Accord Start Up and Review 2.2 L 4-Cylinder ... SIR B16A Engine sputter/ power loss at higher RPM - Duration: 1:14. by ... 1994 Honda Civic Check Engine Light Code Retrieval Tutorial ...
All comments on How To Solve Honda Idle Problems ...
https://www.youtube.com/all_comments?v=L788jKEVblY
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Acceleration Bog/Sputter/Hesitation - Honda-Tech
honda-tech.com/honda-accord.../acceleration-bog-sputter-hesitation-279...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
Dec 28, 2015 | Honda Cars & Trucks
Grinding noise at high rpm
Have you had fuel pressure tested, as well as exhaust for possible plugged catalytic converter?
May 20, 2014 | 2004 Kia Sedona
No power on up hill
Loss in power usually means that the combustion chamber in your cars engine is full of carbon. That is left behind because of the unburned fuel. With that type of problem, fuel responses will be slower, poor acceleration, lower rpm, etc. You may overhaul your engine for them to clean the carbon manually, but it'll be expensive and could lead to "loose compression". That means the engine won't be as powerful or responsive as before.
The best way would be to have a carbon ridding solution injected into the engine. The solution will liquify the carbon and other build-ups, which would then restore the "power" of your car. You'll get better acceleration, higher rpm and top speed, etc. have a mechanic do it for you. It's alot cheaper and faster than having the engined overhauled.
Sep 11, 2012 | Cars & Trucks
Power (acceleration) loss at mid-high RPM only
Loss of acceleration, the backpressure noise and such are kinda tell tale signs of that converter having problems, feel the exhaust out of the tailpipe it will be warm normally have someone step on the gas and if its super hot it'd be a step in the right direction.
Jul 23, 2010 | 1991 Buick LeSabre
Intermittent poor acceleration, loss of power. Has
How is your charging system? Sounds to me like it's not charging your battery, so it runs until the battery cannot support the ignition load.
Apr 24, 2017 | 1992 Buick Park Avenue
Engine code giving misfire on 4 o 5 and P1521 oil contamination
check cam sensor,if the timing isn't adjusting with acceleration then you would have noticable power loss
Sep 25, 2009 | 2005 Jeep Grand Cherokee
Loss of power on acceleration. engine bucking.
check transmission fluid.change fuel filter and air filter.try changing up on where you buy gas .because bad gas causes problems.
Jun 26, 2009 | 1999 Ford Taurus
Metra 2000 Chevy Tracker/Metro/Prism Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
