Taking on a tv hdmi samsung l32r31s a bad contact.Vous have a power kit repaired
2 Suggested Answers
eciampa
  • 213 Answers
SOURCE: I have a 7 year old Phillips 50" plasma. The HDMI port has gone bad. Is it a repairable item?
The HDMI port on your television can be replaced easily by someone that knows how to solder
Posted on Sep 10, 2014
SAMSUNG lcd tv hdmi repair
The first thing you need to do is go into the settngs menu and see if you need to enable it, if there is no such menu setting, you need to change a board on the unit or use the repair kit if you are good at soldering http://www.shopjimmy.com/samsung-bn94-02077c-main-board-component-repair-kit-for-ln40a550p3fxza.htm
Apr 28, 2016 | Samsung LN40A550 LCD TV
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2016 | Samsung Televison & Video
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Samsung tv powers off, is the problem the power supply or main board?
Samsung Power Supplies are prone to failing electrolytic capacitors, you could consider buying one of the many Repair kits available, or go for the more expensive but less skill required power supply board swop,
Samsung Repair Kits : TV Repair Kits MBTV Electronics
Samsung PSU's :
http://www.mbtvelectronics.co.uk/product-category/led-tv-parts/psu-boards
Dec 09, 2015 | Samsung UN40H5003 40 Inch 1080p 60Hz
Can u show me a diagram on how to wire my blu-Ray to my samsung smart tv
You dont need a diagram. Take a HDMI cable from the blu ray to the TV input. Take note if it is HDMI 1 though 6 and switch to that input to watch it.
Jun 13, 2014 | Irwin American Tool 17105L Carbon Door...
Plasma tv video
Could be the power supply inside the TV is bad. Check with your local authorized Samsung repair center. DON'T try to fix it yourself.
Dec 03, 2013 | PN50C675 Samsung Factory Refurbished...
Power Supply BN44-00158A with bad ICP801S but can't read its marking on this surface mount 8 pin chip, need it part number.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 21, 2011 | Samsung LN-T2332H 23 in. LCD Television
My 62 inch samsung hdtv makes a loud buzzing noise no picture but i got sound
Hi, Sounds like you may have an inverter panel failure or even a power supply failure, samsung are known to have bad capacitors on the power supply panel that can cause havoc with you tv in many ways, you can usually get repair kits for this kind of fault or simply replace the board if one is available. There could also be bad or cracked solder joints that may need re-soldering.
Here's what normally happens to the capacitors on the power supply panel... (pic Below) they leak dry up and bulge.
Replacement usually cures alot of faults, but you have to make sure the values are correct, as the are written on the capacitors themselves, I.E. Voltage (V) Capacitance (uF) and Temperature (105oC).
If this is beyond your capability or you are in any doubt please consult your local trained TV Technician.
Never attempt a repair yourself if you dont understand the risks you are taking!
If your TV is under warranty contact your dealer for replacement or repair.
Hope this helps.
Midge.
Feb 10, 2011 | Samsung Televison & Video
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
