Question about Maytag MMV4203D Microwave Oven
Maytag microwave that has a code of 5E - Maytag MMV4203D Microwave Oven
2 Suggested Answers
SOURCE: Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Posted on Jun 21, 2010
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
What does the code 5E mean
The 5E (SE) code indicates a problem with the keypad. A temporary solution may be to unplug the microwave and then reconnect the power cord. (Since the MMV1163DB is a microwave/hood, you may find it easier to turn off the power at your circuit breaker.)
However, you will probably need to replace the keypad or fix the wiring between the keypad and the control unit. If the microwave is under warranty (1 year from date of purchase), contact Maytag at 1-800-688-9900 . One potential solution is to check for damage to the wire between the keypad and the central control unit in the microwave. If you are handy, you can try the procedure that can be found with a Google search. Look for a link to an ApplianceJunk.com forum on the 5E code. However, I can't recommend the procedure for most since it is very easy to break the ribbon cables or their connecting tabs. http://www.maytagpartsonline.com/modellookup/index/thirdstep/keyword/MMV1163DB/model_no/MMV1163DB00/model_id/351623/diagram_id/10797553 has the parts breakdown for the microwave. Check for the correct panel based on the exterior surface of your microwave.
I hope this helps.
Aug 13, 2015 | Maytag MMV1163DB Microwave Oven
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Maytag Microwave MMV4203DB00 HAS A 5E CODE AND IS NOT WORKING AT ALL WHAT CAN I DO?
Hai,you unplugg it for few seconds and reconnect if doesnt clear its a pc board problem which will need atechinician
Sep 12, 2014 | Microwave Ovens
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair.
Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
Jan 05, 2014 | Maytag MMV1153A Microwave Oven
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced.
It's actually a pretty simple DIY repair.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
Jun 08, 2010 | Maytag MMV4203D Microwave Oven
Maytag MMV4203D Microwave Oven Logo
35 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
