Question about Toshiba e-STUDIO 352 Black and White Copier
How to replaced developer in toshiba e studio-352 will i had try with 200 but still machine value is showing error
  • Toshiba Master
  • 643 Answers
After replaced the developer material, u need to perform auto toner adjustment 05-200 ( take out the toner )
Posted on Dec 25, 2015
  • 30 Answers
SOURCE: I got a C440 error code sub code "7" with Toshiba
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Posted on Aug 14, 2010
  • 79 Answers
SOURCE: toshiba studio 352 dispose of used toner
The waste toner bottle is located behind the front cover, you should be able to open the cover and remove the clear plastic container. After emptying the container, you need to make sure that the portion of the container that comes in contact with the sensor on the machine side is clear of any toner, as the sensor sends a beam of light through it to determine if the container is full. After doing this, you may need to reset the machine.
-David.
Posted on Oct 30, 2010
  • 19 Answers
SOURCE: Hello, I turn on my Toshiba E-Studio 166 Photocopy
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Posted on Jan 26, 2011
  • 10 Answers
SOURCE: toshiba e- studio 200 machine sow dispaly need
Reset 08-673, the drum life counter
Posted on Feb 09, 2011
djuksoni
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
My Toshiba e studio 352, when i copyed 200-300 pages then suddenly error occour e 010 then the machine does not copy a single page, cooling/stop machine 10 or 20 minute then i start copying again
sounds like it got a bit hot
tray holds 500 pages doesnt mean it can copy 500 in one session of copying time
Toshiba Studio 352 Copier Studio352
cant see it but
I was looking at the specs to see how many copies per hour it is rated
Jul 03, 2016 | Toshiba Office Equipment & Supplies
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
TOSHIBA E-STUDIO 352 ERRO E550
It might be due to sensor faulty. Perform following input test.
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Exit area Jam access cover Exit sensor 03-[FAX]ON/[2]/[B]
May 22, 2012 | Toshiba e-STUDIO 352 Black and White...
Power Failure in viewer. Paper now jamming also. Toshiba e-studio 352
double press the fc button the machine cannot be switvhed off at the power switch it must be shut down press energy save button and shut down what paper jam error codes does the machine give
Feb 17, 2011 | Toshiba e-STUDIO 352 Black and White...
Can you please giv a soluton for this issue: error code CE 40 toshiba e studio 3520
CE40: Image quality control test pattern abnormality: The test pattern
is not formed normally. If you switch off at the right hand side of the machine, wait
10 secs then back on again, It should clear. I think it is caused by condensation.
It can also be transfer belt failure, or paper rubbing against the transfer belt. It could be
because the Developer Unit failed to Pass the Close Looping Check by the machine
every time it boots.... check for fault from 08-824 if the value of any color is " 1 "
means abnormal occur.... check for foreign matters on the dev tank...the
simplest way is clean all 3 tanks...then reset it back to "0" then do a 05-200 and
05-396-4-Fax-1624-Set
95% solved the case
Jan 15, 2011 | Toshiba E-Studio 3511 Color Copier
Broken registration
If broken registartion, try to initialize the machine by pressing *+1+3 and ON the machine.
What is the error code of CALL FOR Service ?
Press clear+8 to check the code...
Mar 06, 2009 | Toshiba Estudio 200L Copier
Toshiba e-STUDIO 352 Black and White Copier Logo
99 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
