Question about Refrigerators
Hi I have a Brandt combi CO29BWLU. It has begun making an insane amount of ice-up in the freezer. The door also doesnt shut tight, so have begun to use duct tape to pull it shut, but still over-freezing!
dcp2
  • 63 Answers
SOURCE: freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Posted on Jan 28, 2008
  • 1314 Answers
SOURCE: Fridge door does not
you can tilt it back a little rule of thumb that i use is to tilt them back open the door as normal let it go and see if it shuts its self if that doesnt work let me know we will try something else
Posted on Feb 10, 2008
tech master
  • 120 Answers
SOURCE: too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Posted on Nov 03, 2008
rpbuice
  • 161 Answers
SOURCE: Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Posted on Dec 21, 2008
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
How do I control the amount of ice in the freezer? When I open the freezer door ice pours out onto the floor and in the freezer itself.
That is going to a internal problem in the icemaker,is has a sensor that when it detects that the ice bin is full its supposed to cut off the icemaker so it doesnt overflow and continue making ice such as your experiencing. By replacing the icemaker it will shut off when the storage bin is full.
GENE
Sep 26, 2011 | Refrigerators
Ice machine doesnt make ice quick takes a long time to replemish
You may have an air circulation problem. Is your freezer packed tight with lots of food? If it is, you may want to take some of it out and allow air to circulate in the freezer. Also check the vents in the back to make sure they're not blocked with anything.
Jul 21, 2011 | LG LFX25971ST Bottom Freezer French Door...
Freezer keeps frosting up
Hi if this is happening on and off, where the frost goes away and comes back, your freezer door or one of the fridge doors is not getting shut all the way, this is very common on the french door models, if this model has a door alarm marke sure its on, sometimes they are cracked so slightly that the door alarm doesnt pick it up, so you just have to make sure that all doors are shut tightly should take care of your problem.
Sean
Mar 30, 2011 | Whirlpool GX5FHDXVY Stainless Steel (248...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Freezer door not sealing
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Single door frig with top freezer
you can loosen the bolts and adjust the door and then tightened the worst t6nhat can happen is the repair lady deal again
Mar 12, 2009 | Frigidaire FRS26KF5C Side by Side...
Firdge not cold on a combi fridge freezer
possible ice build-up behind the inside rear panel. you have to remoive panel defrost ice with hair dryer then replace the heater/defrost cable. the job cost around 125. for an appliance tech to fix it hope this helps...
Sep 22, 2008 | Refrigerators
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
