My flavia 400 lcd is bad
The lcd cannot be seen. back light is ok....where can I purchase a new lcd?
    Welcome Back:
    Visited the website for 2 consecutive days.
There must be a contrast adjustment knob somewhere.
Posted on Sep 11, 2019
    Top Expert:
  • 14,553 Answers
Likely not the display itself but if so the cost of that part is more than the cost of a new set.....
Posted on Dec 03, 2012
  • JIM TURNER Dec 03, 2012
    What? how do you know that? And it is a coffee maker not a tv set. Anew coffee maker like this is over $1200.00
SOURCE:
I have a Dell 1525 Inspiron laptop. All of a sudden it DOES boot up, (I can hear the HDD) the LCD display looks lit up, but NO DISPLAY either of boot up or windows. I hooked up an external monitor an
It sounds like your LCD might be bad. The fact that you can see the display on an external monitor tells you that your video card on the motherboard is ok. Is it booting all the way into windows so that you can see the desktop on the external monitor? Take a flash light and look real hard at the LCD on the laptop. Sometimes you might be able to faintly see the same thing you are seeing on the external monitor. If you can faintly see the icons or desktop that means your LCD Inverter is bad. If you see nothing, you screen probably needs to be replaced. I would find another repairman because you don't need to know anything about the bios to replace the lcd monitor. Look on ebay and type in "Dell Inspiron 1525 LCD Screen" . Set the options to "Buy It Now" so that you can only see the items you can buy and not bid on. Also set the Sort By to: "Price + Shipping Lowest First". The first thing you will see are LCD Inverters that can be purchased new for under $10, then you will see used LCD Screens from $50 - $75. A new LCD Screen for your system can be purchased as low as $86.69. Also notice that it shows that the screen will not only fit your dell inspiron 1525, but also the 1501, 1505, 1520 and 1526, so once again it sounds like you need to boot the repairman that says you need to know the bios number. If you need a good hones repairman try: http://www.generalsystemsconsulting.com They will fix it and ship it back to you for less than any quote you get including the shipping. I had a friend that got a quote from HP of almost $400 to replace the screen, they did it for $155
Mar 19, 2012 | Dell Inspiron 1525 Notebook
Need a Flavia 400 service manual
Hello :
Here you are : http://www.myflavia.co.uk/support/flavia-user-guides/
good luck
rate if useful please !
Feb 15, 2010 | Coffee Makers & Espresso Machines
How do I remove the exterior side panels from a Flavia 400 beverage machine?
Remove drain tray. Four screws on inside wall. Open top fill point and remove white strainer tray. 3 screws under tray. 2 more in back of machine. Side panels sort of pop-slide outwards. Please note that this is not a simple machine to fix. (even for us techs) lots of plastic that can snap off. Suggest turning into service center. also note that the most common problem with the 400 is a stuck packet which can be removed by bending a large paper clip straight and making a small hook on the end to try to catch the white tip on the package with a good yank from the front. Good luck!
Feb 13, 2010 | Coffee Makers & Espresso Machines
Where can I purchse new lens/lamps at for my Mitsubishi vs 5047?
Is this a CRT (picture tube) or LCD, DLP projetion set. DLP and LCD are lamp driven CRT have three picture tubes (red green and blue). You can tell by looking at the back pof the set if you see the glow of white light than it's a LCD or DLP. Lamps can be purchased at "bluestar international" ($100-$400) (google it) and CRT's are not worth replacing (over $300 each_)
Sep 20, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
Flavia Coffee Maker coffee sprays outside cup
I bet that's wild thing to see. Ok, Is ther a basket that'ds supposed to be there? If not,heat up a large paper clip,straightened of course and run it yhrough the hole. If the nozzle will come off, clean the burrs of the edges of the hole on the inside. It sounds like it's restricted if it's spraying. Good luck
Jul 10, 2009 | Coffee Makers & Espresso Machines
LCD display is gone. On speedo but back light is still
Treat as for a bad connector - take it apart, spray liberally with WD-40 or CRC and reassemble.
Jun 25, 2009 | 2001 Suzuki DR-Z 400 SE
I have a Fuji Finepix S9600 with damaged LCD screen
send your camera in to fuji's repair center, and they can replace the screen
Mar 22, 2009 | Fuji Finepix S9600 Digital Camera
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Ekse
