Question about Ovens
Whirlpool AKP 951 timer does not work
My Bottom Oven does not work on by Whirlpool AKP 951. The oven has been switching itself off a lot, or would not turn on. Now the Clock/Timer has gone blank, so I cannot turn the oven on (Hob and Top Oven are ok)
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
BElectric
  • 1140 Answers
SOURCE: my oven has stopped working
Hello Janet,
Can you let me know the brand and model number of the oven please. Your oven should work again as soon as you cancel the timer or set the clock and the digits stop flashing, but I can't tell you how to do this without knowing which oven you have.
Thanks,
BElectric
Posted on Mar 22, 2011
I have a whirlpool built in oven AKP 239/IX/02 When I try to turn the oven on (both dials) the sign "- - - C" discpays on the digital display screen and the oven will not turn on.
We're sorry to learn of your experience. For further assistance with your Oven, we recommend the link below. You may contact our counterparts in your Region due to you are outside the US.
http://www.whirlpool.co.uk/
Jan 17, 2018 | Whirlpool Ovens
Whirlpool Absolute Built-In Oven in Stainless Steel AKP 7460 IX user manual ?
Dalene, we recommend the link below for the User Manual.
http://www.whirlpool.co.uk/appliances-1/ovens-3/whirlpool-absolute-built-in-oven-in-stainless-steel-akp-7460-ix/857774601700/
Jan 16, 2018 | Whirlpool Ovens
Manuel for Whirlpool model WRLPL AKP 262/1X SGL Fan oven
My oven decided to error code loc please help!
Feb 25, 2012 | Whirlpool Ovens
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Noisy oven
Probably the fan bearing is worn out, looks like you will need a new fan.
Make sure there is not any obvious visual obstruction.
Jan 10, 2010 | Ovens
Oven turns itself on???? Timer beeping when family woke up???
Sounds like someone messed with your timer... Easy reset: turn the breaker off and back on...reset clock... woo hoo!
Jul 30, 2009 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
