Indesit wil163 washing mashine lights flashing and wont start up
Hiya, hope you can help my indesit wi163 is only 3 years old and for some reason has stopped working, the delay timer and the extra rinse green lights are flashing and the red door lock light is flashing rapidly .. then fter 20 minutes all the lights go out and nothing I turn it back on and the same action is continious ... ive tried turning off and on but doesnt help ...any helpful advice or little tips I could use before calling out someone .. thank you x
  • 209 Answers
SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Posted on Sep 25, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: hi,i have an indesit wil
sounds like motor carbon brushes need replaced .
Posted on Sep 25, 2008
  • 1474 Answers
SOURCE: I have an Indesit WIDL 126 washer/dryer. When you
Check delay swith has not been operated also try resetting prog.. handbook shows you this,
Posted on Sep 28, 2009
  • 86 Answers
SOURCE: Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Posted on Mar 21, 2010
Door lock and extra rinse light flashes
is it the tub that clunks?was it very noisy in the spin cycle?if so the spider gear is gone and it would be cheaper to replace the should only be adding two tablespoons of soap that's it,alot of people use to much soap and it eats at the spider gear,if you look inside the tub at the back wall you'll see a piece sign,that's the gear located on the back of the tub
Nov 09, 2017 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Beko 1512s problem
sounds like there is a fault on the machine, when the timer starts clicking the doorlock light will flash a number of times, you will need to count these flashes as this will give an indication of the fault.
hope this helps
please dont forget to rate this answer. thanks kj
Jul 25, 2008 | Indesit W 123 Front Load Washer
Indesit W1A 111 front load W/M
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Click above (ie. below the Fixya symobol, on yr model No. You will come to Troubleshooting & Support. There is a posting by "again". First 5 postings?
May 07, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
