Question about Casio FX-115ES Scientific Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
How is this done
  • 3 Answers
If you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Posted on Jun 09, 2009
Descaling light on Machine done des ale as per instruction but light still on why?
how old is it and how many times have you done this,some machines need it done again x2 if never done before,
Jun 16, 2017 | Coffee Makers & Espresso Machines
Tip
Sciphone i68 AT&T GPRS & MMS Internet Settings
Thanks to the author, follow these steps:
GO TO SERVICES AND FOLLOW THE FOLLOWING:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT ANY OF THE PROFILES LISTED(EXAMPLE CHINA MOBILE)
A SCREEN SHOWS ACCOUNT NAME, APN, USER NAME AND MORE
EDIT ACCOUNT NAME TO AT&T, GO ON OPTIONS AND PRESS DONE
EDIT APN EDIT TO wap.cingular (lower case), GO ON OPTIONS AND PRESS DONE.
EDIT USER NAME TO WAP@CINGULARGPRS.COM (UPPER CASE) AND PRESS DONE.
EDIT PASSWORD TO CINGULAR1 (UPPER CASE) AND PRESS DONE.
EDIT AUTH. TYPE TO SECURE.
SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
GO BACK A COUPLE OF TIMES UNTIL THE OPTION WAP AND DATA SUPPORT APPEARS AGAIN
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT SIM 1 OR SIM 2 (OTHER SIM NEEDS SETUP IF BEING USED ALSO)
IF AT&T APPEARS SELECT IT, IF NOT EDIT ANY PROFILE AND RENAME IT AT&T.
SELECT EDIT PROFILE
GO ON HOMEPAGE AND CHANGE IT TO http://device.home lower case)
GO ON DATA ACCOUNT, THAN GPRS, AND SELECT AT&T.
GO ON CONNECTION TYPE, ITSHOULD READ HTTP, PRESS ON IT, SELECT HTTP
ENTER PROXY ADDRESS 066.209.011.032
ENTER PROXY PORT 8080
PRESS OK THAN SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
SELECT ACTIVATE PROFILE( ATT WILL APPEAR AS SELECTED)
THE PHONE IS READY. GO TO SERVICES AND SELECT HOMEPAGE FOR INTERNET.
MMS SETTINGS
1. Select Messages
2. Select MMS
3. Select MMS Settings
4. Select Edit Profile
5. Select any profile
6. Choose Edit Profile
7. Edit Rename Profile to AT&T MMS
8. Press Options
9. Press Done or OK
10. Edit Home Page to http://mmsc.cingular.com
11. Press Options
12. Press Done or OK
13. Select ATT MMS and press OK
14.Edit Connection Type to HTTP
15.The IP address is 066.209.011.032 and the port number is 8080 and press OK
16.Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
17. Press Options
18. Press Done or OK
19.Edit the Password to CINGULAR1 (UPPERCASE)
20. Press Options
21. Press Done or OK
22. Press Done
23. When prompted to SAVE please select Yes
24. Select Activate Profile and yes.
on May 08, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How to save new contact
IF DONE DOES NOT SHOW THEN MAYBE YOU CLICKED UPDATE CONTACT BY MISTAKE. Click " new contact"
Type number > press options > save number > new contact > click done when finished.
Try scrolling past some of the boxes where you can type until the "done" appears. Try adding info if that does not work.
Try clicking options and then closing options, does done appear?
Apr 03, 2016 | Tracfone Wireless LG 440G
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do i change from getting answers in fractions to decimals on a casio fx-83ES?
Change the Input/Output Mode to LineIO. Press [SHIFT][MODE] and select [2:LineIO].
Aug 07, 2011 | Casio fx-300ES Calculator
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
How can i convert a decimal degrees on my casio fx-9860G AU PLUS to degrees,minutes,seconds
Use the ->DMS command in the [OPTN]-[ANGL] menu. Press the OPTN key, then select ANGL.
May 21, 2011 | Casio FX-115ES Scientific Calculator
How to set GPRS in my phnone t13 duo?
Action Selection Settings Press Menu Select Services Select Data Account Select GPRS Select Account Select Account Name Sun INTERNET Select Option Select Done Select APN minternet Press Option Press Done Select Username Leave User name Press Option Press Done Select Password Leave Enter new password Press Option Press Done Select Auth. Type Normal Press Done Press Save Yes Press
Substitute your carriers setings for the ones above
Back 4x
May 02, 2011 | Computers & Internet
Casio FX-115ES Scientific Calculator Logo
1,807 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
