Question about Samsung PS50A466 50 in. Plasma HDTV-Ready
My 50 inch sanyo tv comes on and stays on but no picture or sound what can i do to get the picture and sound
  • 85 Answers
Check power board re bad caps also check all av cable fittings
Posted on Dec 03, 2012
5 Suggested Answers
GadgetRaja
  • 150 Answers
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Posted on Sep 02, 2009
  • 129 Answers
SOURCE: the tv has no picture but sound can be heard. how
Try connecting a different device to the TV and check. You may also try changing the cable to connect the device to the TV and check. If the issue persists, try resetting the TV to the factory settings, then try power reset. To power reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV. If the issue still persists, then service may be required.
Posted on Jul 26, 2010
rdcomprepair
  • 122 Answers
SOURCE: no picture, just sound on my 50 inch plasma tv
Does it show a Menu at least? If it does then just switch through the INPUT until you see a picture. Cables most likely to be Video 1, 2 or 3. Video games "LINE", or HDMI..of course "HDMI".
Your remote should have an "INPUT" button.
Posted on Aug 21, 2010
freetek
  • 5568 Answers
SOURCE: I have a 2 year old 50 inch samsung plasma tv -
I don't know your set but the way it failed is noteworthy and possibly revealing.
Plasma sets have a little in common with the sets of 30 years ago; they use phosphors to convert electrons into light and the electrons are accelerated with a high voltage.
Loss of the video first indicates the high voltage section (or separate supply using input from a main supply) failed in a way causing the main supply to fail with the loss of audio and complete death.
If it was my set; I would pull the AC plug, allow the set to remain overnight to allow any residual voltage to decay, remove the back, look for a separate assembly the seems related to the AC cord coming in. This should be the main power supply and will have a primary fuse which is likely blown. If it isn't soldered in, replace it. If it blows again, you will need a tech to proceed. The second failure means the high voltage section (or separate supply) has a component failed that is causing the main supply to fail or at least overload so replacing it again isn't logical or productive. If it doesn't blow, you will probably only have audio and a separate fuse in the high voltage section has blown and protected the main supply from damage. It isn't likely that replacing the supply (or supplies) is a straightforward DIY project and there is a slim chance even if you did, that the plasma display is faulty and that the failure would repeat itself.
Because of the problems with shipping a set of this size unless you have retained the original packing material means you will need on-site service and it will be expensive.
It's a pity, but a fact, that our much more complex sets are just not as reliable (at least yet) than the mature designs of the earlier conventional TVs.
Posted on Jan 27, 2011
Where is reset button on sanyo 50 inch tv model DP50740 The TV will not stay on
There is no reset button on televisions. I see that is a plasma set, if you are just losing the picture that is one thing, if the whole set is shutting down, that is another. Please advise
Feb 02, 2016 | Sanyo Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
They only sell circuit boards so unless you have the skill and equipment to locate where the problem is have a shop look and get an estimate for repair.
Dec 03, 2012 | Televison & Video
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung PS50A466 50 in. Plasma HDTV-Ready Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
