Question about Toshiba 65HM167 65" Projection Television
65" projection toshiba power fuse blows
The power fuse keeps blowing when we connect it to the cable for the satellite. We have tried a 7 amp fuse and a 6.3 amp fuse. Both keep blowing when the cable comes in contact with the television. The cable works fine with other televisions so the cable is not the problem. What could be wrong with the TV?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
You have a dangerous situation here---All modern units (Lamps, TV's, everything) Have a polarized power cord---one side of plug the pin is smaller than other side.
The large side goes to the neutral side of the electrical outlet.
One of two things has happened---either a issue with the electrical outlet which is rather rare except in older houses that have the old style electrical outlets (both pins the same size) Or someone has managed to get a cord in backwards--filed down the large lug on the power cord and put it in backwards.
What happens and can be tested is with it backwards you have "potential" 120 volts being fed back into the cable wire itself--
DO NOT KEEP CHANGING THE FUSE--a simple test with a voltmeter set to AC (wall) voltage from a earth ground (water pipe of metal will show 120 volts on the coax.
The touchy part is any set in the house misconnected can feed this back via the coax!
The cable company may be able to help or NOT> an electrician will be able.
The way I would locate this is with the volt meter hooked to the coax I would disconnect the cable feed from each set or unit in the house one at a time until no voltage reading---then you would know which is causing this issue.
Be advised it can spark which can destroy parts in any of the sets or equipment.
Kind of like if you got shocked when you touched the metal on your car.....something bad is happening.
Please if need ANY help comment here and I will assist.
Posted on Dec 03, 2012
  • Angela 'Hamby' Byers
    Angela 'Hamby' Byers Dec 04, 2012
    What if the power cord in the back of the TV got switched around? Would all connections put out a spark such as the DVD player, VCR, Blue ray? Because only the satellite receiver is the one we have issues with. The TV repair guy noticed an issue with what you said. When he switched the cord around the voltage went down. The only thing is that when connected to the satellite receiver it throws a spark and reads 120 volts. When connected to all other items there is no spark and reads only 60 volts. I ordered a new receiver to see if this is the case. I will comment back when I do find out if it is the receiver or TV. Thank You! You hit the nail on the head with what I was told yesterday!
    Angela 'Hamby' Byers Dec 07, 2012
    Ok I got the new receiver and it still reads at 120V and when touched to the back of the TV throws a spark. So...it is not the receiver. If the TV has an issue with the polarized power cord how could this have happened? and is it fixable? The cord is on properly. The black is on the black side and white on white.
  • 103 Answers
SOURCE: blown fuse over and over
you need to solder all the connectors and plugs between the 2 boards
Posted on Mar 06, 2007
  • 1694 Answers
SOURCE: convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Posted on Jan 27, 2008
ctf1800
  • 4402 Answers
SOURCE: 65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 21, 2008
Cybertech
  • 149 Answers
SOURCE: blinking power light
depend on how U use it and how long is recommended that after 4 hour es of use turn it of 5 to 10 minutes to let the lamp cool off no some laps use are between 7 to 9 thousand hour
Posted on Apr 03, 2008
SOURCE: toshiba 36zt29b television
Hi, I am an idependant service engineer, who is currently looking at one of these actually a 36 inch 36zt29b. So far, it looks likely the digital board is at fault sending an 'off' signal to the digital power board. The digital board itself is no longer available. I am going to have a look at this board, and try to fault find it. If I have any success I will post again.
Posted on May 08, 2008
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
May 24, 2014 | Definitive Audio Players & Recorders
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Mar 18, 2014 | Radio Shack Audio Players & Recorders
ATTn SD Tech: my 65" Mitsubishi keeps blowing the
1,2 means no error found. To confirm turn set off and unplug and and turn back on, when it fails try the self check again.
Where did you buy the replacement fuses? Radio Shack?
Some of these fuses are special and the poor ones which are generic will pop for no reason sometimes; examine original fuse and holder for correct amperage and type of fuse used.
sd tech
Sep 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My toshiba satellite M100 keep turn off, why?
I use a Satellite. They are not heat friendly. Use canned air to blow out the vents on the side & back and blow out the fans on the bottom. Get a cooling fan for under the computer. Try to use it on a firm or hard surface since a soft surface won't allow air flow. Blow it out at least every 2 weeks.
Sep 30, 2009 | Toshiba Satellite M100 Notebook
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
I have a Toshiba 61H71 that keeps blowing F850. It was just sitting there the first time it did it. I didn't have a replacement fuse so I temporarly replaced it with a 3A glass barrel type fuse. This...
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
Apr 15, 2009 | Toshiba 61H71 61" Rear Projection...
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 65HM167 65" Projection Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
