Question about Ovens
Fan oven stopped heating suspect it is the thermostatic switch not the elements
Fan oven not heating but light and fan still working. Something appeared t o have snapped in switch as I turned it on.
    Top Expert:
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 03, 2012
4 Suggested Answers
  • 6 Answers
SOURCE: Thermostat or Heating Element?
Check out our element replacement guide at: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Feb 28, 2007
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Posted on Aug 18, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SMEG OVEN BRAND NEW WON'T HEAT
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Sep 08, 2012 | Smeg Ovens
    I have just replaced the fan for this oven as it had stopped spinning. However it appears not to be the fan that has broken as the new one behaves the same. One important obserbvation is that when you...
    Strange one this. According to the wiring and circuit diagrams, the yellow wire from the fan should go to contact 4 on the main oven switch. The oven element is connected to the thermostat, which in turn is connected to contact 3 on the oven switch. When the oven is on the handbook says that contacts 1,3 and 4 are made, contact 1 being the oven lights. So if the lights come on and the fan turns, the switch is more or less working. The only other thing that overrides the oven element is the thermal cutout. If you still have the problem, let me know what the thermostat neon is doing in all of this. It will be interesting to see what this is doing. Also, if you want the handbook which includes the diagrams, post your email address and I will send you a pdf copy.
    May 12, 2011 | Stoves 720EF Electric Double Oven
    We have a fan oven, which started not heating, but fan and thermostat light still on! We thought it was the element! But now the oven is working very occasionally, still heating as normal! We can try to...
    Elements don't heat intermittently - if the element is good it will heat up every time. If the element is blown / burnt-out it wont ever heat.
    As your oven is heating sometimes but not others, this means the power supply to the element has an interruption somewhere. This could be caused by any of the following:
    1. Loose connection in the wiring at the switch or the element
    2. Faulty switch
    3. Faulty thermostat.
    4. Faulty oven timer
    The thermostat is effectively just a heat-sensitive switch. By default it should be "closed" allowing power to the element. When the oven reaches the desired temperature, this switch opens, cutting power to the element until the oven cools enough for the switch to close and allow power to the element again.
    Any of these four could be the cause of your fault. Loose connections can often by located visually, however testing a thermostat for correct operation and calibration is more complicated and ideally requires test equipment. The timer is the least likely cause, so I would concentrate on the others first.
    Repairing your oven or any other electrical appliance can be dangerous and many repairs require specialist knowledge and/or electrical test equipment. Please bear this in mind before and when attempting any repair or consider having your appliance professionally inspected.
    If you are intending to investigate this problem yourself, please ensure the power is disconnected at the wall/breaker first. Initially, I suggest that you visually check the connections at the element and the switch. You may find a wire at one of these locations that is partially broken or detached. Personally, I suspect your thermostat may be faulty.
    Hope this helps.
    Regards,
    BElectric
    Jan 01, 2011 | Ovens
    My cooker won't heat up
    remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
    Jul 23, 2010 | Electrolux Ovens
    Fan not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
    The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
    The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
    Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
    6200.5 fan works but no heat and light remains off
    I suspect that from the symptons you describe that the fan oven element is faulty, the other possibility is that the thermostat is faulty, even if the element is faulty, the thermostat indicator light should come on.
    Please rtate my solution.
    Thanks.
    Nov 08, 2009 | Kuppersbusch EEB62001 Electric Single Oven
    Fan oven on zanussi electric cooker does not heat up
    From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
    Plz rate this solution.
    Thanks.
    Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
    My neff oven b1664 rear fan element stays on after switched off
    I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
    If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
    Dec 11, 2008 | Ovens
    Oven not working
    for darnos
    have you reset the clock? this needs doing after you lost power. i suspect you have it on auto
    for jez-cath and wilana
    in both cases, probably the fan element at fault.
    Feb 12, 2008 | Smeg SE250XUK Stainless Steel Electric...
    Ovens Logo
    59 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
